Funny running?
From: Dewsbury, The parts were they don't abduct their own children!
In the mornings my saphh cossie struggles to stay running? It starts fine runs for a few seconds, struggles then cuts out. Start it up again and the same happpens. If you give it a few revs or set of driving it's a little lumpy until you've done a few mile.
Seen as i kept it garage over the winter ( I did start it up though twice a month and let it run to temp) i thought it may be dirty spark plugs?
Any thoughts on the subject ? any help?
Darren
Darren
ISCV?
Not too sure what that is? Something to do with cold start? or throttle control??
Could just be the plugs, im sure the c57c`s are lumpy on start up, altho im not sure what you have, also the 071`s if not gapped correctly can be bad for it, get it in for a set up and im sure iy should get sorted
Sounds like the idle control valve, I had this problem on mine, I found that the idle speed screw was wound in too far. You may find that the plug on top of the valve has corroded a bit causing it to malfunction.
I find there is an art to keeping them ticking over. I took mine to have new tyres fitted today and it kept cutting out on the fitter guy....tut tut. Not experienced in the ways of the old ford...
Eigdoog
Sep 13, 2015 05:46 AM
