Bigger brakes....
Old May 11, 2006 | 12:51 AM
Sean_RS's Avatar
Sean_RS
Default Bigger brakes....
right.. what do i need?
Old May 14, 2006 | 06:32 PM
Manchester Mike's Avatar
Manchester Mike
Bigger disks
Old May 14, 2006 | 06:52 PM
pollocks's Avatar
pollocks
depends on your budget but wilwoods look good value for money when compared with cossie 4x4 ones
think there around 450 quid for the wilwoods
were as cossie ones you get pads for around 70 discs around 150 and calipers for around 200
all prices are roughly at that and i may be a bit out on the wilwoods
Old May 14, 2006 | 07:02 PM
AGAR-COSWORTH's Avatar
AGAR-COSWORTH
Redumbdancy
Saph Cossie 4x4 Disks and Calipers are a good choice - will fit under most 15's, or ST170 setup but will require 16's. Standard master cylinder should be fine, but upgrade to braided lines.
Old May 15, 2006 | 05:45 PM
jayRS's Avatar
jayRS
i got escort cossie 4x4 set up, all ya need for this is disc, calipers , 4 bolts that are about 10mm longer than standard and some washers to space the cailper out to disk, depending on the thickness of the washers you might only need 2 for each bolt, but the washers need to space it about about 5-6mm
Old May 16, 2006 | 02:51 PM
ballin's Avatar
ballin
4x4 cos setup, ~Ł200 all in
Old May 16, 2006 | 02:55 PM
jayRS's Avatar
jayRS
i paid Ł60 for my drilled and grooved disc and 4x4 calipers, then another Ł35 on new pads
cant remember who i got them from but it was a guy on here
Old May 16, 2006 | 04:31 PM
AGAR-COSWORTH
Redumbdancy
Ive never actually heard people using the Escos setup on a Mk3 Fiesta, is it exactly the same setup as saph disks and callipers?
Old May 16, 2006 | 04:57 PM
jayRS's Avatar
jayRS
yeah the 4x4 stuff saph or escos are the same, loads of people use it and they fit under 15's line mine
Old May 16, 2006 | 04:58 PM
AGAR-COSWORTH
Redumbdancy
yeah the 4x4 stuff shap or escos are the same, loads of people use it and they fit under 15's line mine
Thanks for that, should making finding parts that bit easier.
Old May 16, 2006 | 05:18 PM
jayRS's Avatar
jayRS
yeah no worries mate
Prickly_buzz
Dec 7, 2017 09:52 PM
Fordmad!
Sep 29, 2015 07:03 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
marky_g
49
Sep 22, 2015 09:59 PM
dms04
Sep 11, 2015 01:57 PM
