cosworth rear brake presure control valve
Old May 10, 2006 | 10:02 PM
182sam's Avatar
182sam
Default cosworth rear brake presure control valve
can anyone tell me where i might be able to get one of these as it is a non serviceable item and ford no longer have them, it is situated near the passenger side rear wheel up near th chassis a brake pipe comes from the front goes into this valve then comes out the other side from what i can understand it reduces the brake pressure to the rear wheels, has anyone had this problem and is there an easy solution i.e an aftermarket set up that fits straight on any help would be much appreciated, its for a 3dr by the way but is the same on a saph cossie.
Old May 10, 2006 | 10:04 PM
rapidcossie's Avatar
rapidcossie
i have mine removed and its lying in the shed...
make me an offer
Old May 11, 2006 | 07:15 PM
182sam's Avatar
182sam
rapid cossie pmd you
Old May 15, 2006 | 05:25 PM
182sam's Avatar
182sam
up can anyone help
Old May 15, 2006 | 09:49 PM
steventoon's Avatar
steventoon
you got a picture of what your looking for ?
Old May 16, 2006 | 02:00 PM
2001ode's Avatar
2001ode
I think it is this :
Regards
Claude
Old May 16, 2006 | 05:16 PM
182sam's Avatar
182sam
hi thanks for the picture that might help that is the part i require if anyone has it let me know thanks
Old May 16, 2006 | 10:19 PM
rapidcossie
sorry mate.... ill pm you back
Old May 17, 2006 | 06:22 AM
182sam's Avatar
182sam
rapid coosie pmd you back
Old May 18, 2006 | 04:45 PM
cossietimbo's Avatar
cossietimbo
Yep, I had this problem on both sapphires. U wou't get a new compensator and some people link em out, which is risky.
I can get you a as new one, but it isn't cheap. They came off a new car, brakes stripped prior to rally conversion. Let me know if you want one, Ł130 plus PP.
Otherwise try a scrappy for a one.
Old May 21, 2006 | 07:52 PM
steventoon's Avatar
steventoon
How can you tell when this valve is knackered ?
Steve
Old May 21, 2006 | 08:22 PM
2001ode's Avatar
2001ode
Hi,
Symptoms are kwick wear of rear pads or rear wheels lock up when ABS is disconnected.
Regards.
Claude
Old May 21, 2006 | 10:14 PM
steventoon's Avatar
steventoon
Thanks Cluade,
If they are hard to get hold of then I think I'll try and find a spare now in case mine packs up at some point.
Steve
Old May 24, 2006 | 07:00 AM
182sam's Avatar
182sam
up
original
Apr 28, 2026 05:20 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
track.focus'd
Aug 12, 2015 05:53 PM
Bosch
Aug 4, 2015 05:14 PM
