help urgent
Old May 10, 2006 | 03:05 PM
orion stuart's Avatar
orion stuart
Default help urgent
i had all the tank off and i chaged my feul pump to motor sport one i put it all back together and it wont start it turns over but wont fire and theres no fuel getting to the engine
plz can some one help
Old May 10, 2006 | 03:11 PM
s1 2oobhp's Avatar
s1 2oobhp
is it efi coz u might have the + - wronge way
paul16v's Avatar
paul16v
Monte 087
Not meaning to take the piss but you have wired it up the correct way round havnt you, it would be the first thing i would check?
Old May 10, 2006 | 03:12 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
did you plug it back in?
Old May 10, 2006 | 03:16 PM
orion stuart
it went back the same way it came out
Old May 10, 2006 | 03:20 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
did you take the fuse out the fusebox to run the car and use all the fuel in lines and depressurise the system etc?
can you hear the fuel pump whine when you turn the ign on?
Old May 10, 2006 | 03:24 PM
orion stuart
no i didernt do that
and i can hear the pump
Old May 10, 2006 | 03:27 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
hmm, have you just kep turning on the ign and not try to start the car to build up fuel pressure?
did you connect the fuel lines around the right way?
only other thig is if you wired it up in reverse if you can hear the pump whine
orion stuart
i need it running by sunday for fitp
Old May 10, 2006 | 03:28 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
best go and recheck everything then mate
Old May 10, 2006 | 03:35 PM
orion stuart
ill have to thats all i can think about doin
thanx stuart
DaveN
13
Jan 9, 2005 06:19 PM
R4N SS
Jan 1, 2005 12:17 AM
Walshy
May 14, 2004 01:34 PM
