secs monitor owners
May 9, 2006 | 10:09 PM
secs monitor owners
what water temps are you seeing in this weather.?
May 9, 2006 | 10:11 PM
85 - 88ish for me now Ian.
mines off the road.....typical cossie.
May 9, 2006 | 10:14 PM
about the same as stu.
May 9, 2006 | 10:15 PM
mine was reading 83 to 85 which i thought was a bit low so i put a new coolant temp sensor in tonight and now it reads between 77 and 80.
May 9, 2006 | 10:17 PM
Quote:
Thats what you get for fooking around. ROFLOL
May 9, 2006 | 10:19 PM
meddling at its finest.
i think i,ll put the old one back tommorow.
May 9, 2006 | 10:26 PM
May 9, 2006 | 10:27 PM
Quote:
Originally Posted by markk
FOOKIN MESSER !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
only surpassed by YOU!!!!
May 9, 2006 | 10:30 PM
only EVER passed by YOU!!!!
well, i didnt like to say
May 9, 2006 | 10:38 PM
put the evo stick away its addling your brain.
AND you still havent won your car back from me, and dont even think about a fresh challenge i cant afford to repair the damage to mine when its been hit by bits falling off yours.
May 9, 2006 | 10:42 PM
May 10, 2006 | 12:20 AM
around 82, fans on at 92 then down to 76
Using pace 500 cooler
May 10, 2006 | 05:20 AM
Around 80-85,depends on speed,fan also comes in at 92
May 10, 2006 | 06:38 AM
90-94, fans come in at 93 - is this too high?
Neil.
May 10, 2006 | 07:09 AM
My fans arnt kicking in till 96, need to change my fan switch over.
May 10, 2006 | 07:49 AM
Quote:
Neil.
That is perfectly normal - that is when my fans come in (as I am using Sierra switch).
May 10, 2006 | 08:10 AM
Same here, but as I've never heard my fans cut in, I asked Karl to check to see if they were working when I had a set-up a few weeks back. He found they were cutting in at 96 and said that was ok.
May 10, 2006 | 08:15 AM
mine hangs around 88 ish but i havent really driven it this year so
May 10, 2006 | 08:27 AM
May 10, 2006 | 01:39 PM
Quote:
How is the Escort Lynne? did Oli get all the jobs sorted on it.
May 10, 2006 | 01:42 PM
mine around 80-90 fans come in at 92 i think..
May 10, 2006 | 01:54 PM
Dunno, mines broke!!!!!!!!!!!!!
May 10, 2006 | 07:56 PM
My Dad's has been reading about 25 for the last few days!
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
rsguy
44
Sep 29, 2015 03:29 PM
Mc5506
Sep 29, 2015 09:06 AM
