FAO Stu :)
I had a bit of a drive in the car tonight. First time since I fitted the turbo and the other bits - fook me it flies!!!
23.5 psi at the minute, I figure I'll quite while I'm ahead and leave the other couple of psi to you when it comes your way
Couple of odds and ends to sort out first - I think my ISCV is a bit sticks as it hunts a bit when it's cold, and the other thing is it surges slightly when I back off in the midrange - just one kind of shunt, then it's fine. Do you have any likely culprits for that?
Anyway, I'm well chuffed with it!!
Thanks again for the help and endless patience!!
Neil.
Neil.
PassionFords Creator
Thanks for teh kind words Neil
High timethis machine of yours tasted some tarmac
Likely culprits:
Base idle settings incorrect, fuel pressure. CTS errors +more.
LOL
Likely culprits:
LOL
I've fixed the hunting - cleaned the ISCV out with a bit of carb cleaner and it's nice and even now
The shunt is a bit wierd though
It actually picks up when I back off!!
Anyway, I'll be in touch soon to get it set up
Neil.
Neil.
PMSL the brakes will go on ASAP if I can have the usual terms on a set of MO's Mike?
Been driving it again today - it's fookin ace
Getting used to the extra lag now too
Neil.
Neil.
Neil.
Neil.
PM me what terms you were think of, and I'll get back to you, bearing in mind that there will be a Ł50 price hike on any Compomotive orders placed after 15th May due to alluminium shortage putting the raw material costs up
Neil.
Neil.
It doesnt exist anymore as I'm used to it now!
Fecking thing blew it's Fuel Reg control hose off tonight though
A spot of Araldite should see that fixed
Neil.
Neil.
GTR_STU
Aug 28, 2015 01:02 PM
