18's on a saph
Old May 8, 2006 | 02:51 PM
Tonks's Avatar
Tonks
Default 18's on a saph
How easy do 18's go onto a saph.
Do u need to roll the arches and what does it do to the driveability.
Jamie
Old May 8, 2006 | 08:01 PM
charlie luciano's Avatar
charlie luciano
Default 18's on saffs
18's can go on saffs and it has been done to accomodate massive brake kits, to get the best result i'm told that the arches do need attention in the way of a roll, a coilover suspension kit is also needed to give the ride height adjustment thats required, it also looses the big cup/flange that comes on the standard struts as this fouls if you put 18's on the car,
C L
Old May 8, 2006 | 08:25 PM
DAN P's Avatar
DAN P
as above but some cars needs coil overs and some dont lol you will need 215 35 18 and the right et
Old May 8, 2006 | 09:18 PM
CosKev3's Avatar
CosKev3
As above,will fit
Haven't noticed any difference to the driveability/handling,just the cats eyes feel alot harder
Front arches need a bit rolling,only catch at the front of wing if you are turning and brake or go up a lowered kerb etc
Don't need coil overs ,and don't touch the spring cup on front struts either
Obviously need correct offset,and mine are 215/35 18's
Old May 8, 2006 | 10:32 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Had 19s on mine for a while They were 7x19 fitted with 215/35/19. Coilovers and front arches rolled and liners removed. Only rubbed on back lower edge of front arches when braking really hard. As said above not much different to 17's. Only changed as i couldn't fit a 19 in the spare wheel well.
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
landaqmabba
Sep 15, 2015 07:16 PM
