Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
abs
Old May 8, 2006 | 10:11 AM
ilovestacey's Avatar
ilovestacey
Default abs
hey i thought id tell every1 out there with a puma if u end up putting bigger wheels on u have to move the abs sensors in the iner arch its easy to do cause other wise on full lock the wheels rub the wire away it happened to me and then ur light comes on
Old May 8, 2006 | 01:46 PM
JohnT's Avatar
JohnT
Nice one just fitted some 17's on mine
Old Dec 9, 2006 | 08:35 PM
Antenup5's Avatar
Antenup5
removed by webteam
Old Dec 10, 2006 | 06:11 PM
Dal_'s Avatar
Dal_
Default Re: abs
Never had this problem on mine - maybe cause my alloys have lots of "fresh air" in them
This being the ABS ring behind the hub (the slim ring with rectangular holes):
one thing to look out for if your fitting 17's is to not fit a tyre wider than a 205/40 or else you'll get rubbing like this:-
Unless you've got an FRP of course.....
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
