3door headlight help!!!!1
orion=mini saff
hi all,i cant get my 3door cossie headlights to work
its got its MOT tomoz,and i cant suss it
side lights work,i can hear the relay click,but theres no dip,main beam,all the rear lights work fine,ne help peeps?
i tested the light sockets,there seems to be 2 earths on each side
If the wiring is the same on the saphs, brown is earth (looking at the plug its the one on the right) The other two are dipped and mainbeam I think the top pin is dipped.
There will be two small white (or sometimes blue) relays in the fuse box for the dipped circuit and mainbeam. Double check these arent burnt out or miss connecting. (not usually a problem on the sierras but are on the escort / orions!)
orion=mini saff
cheers mate,must be half my problem,at the mo its showing 2 earths out of the 3 pins
flash works one side,but not the other,on the 3 door,what one does the main beam?is the inner lights?or in the main cluster
Steve Escos
Oct 1, 2015 06:57 AM
