XR2 Water Temp Gauge Not Working
Old May 7, 2006 | 10:30 AM
JohnnyT2's Avatar
JohnnyT2
Default XR2 Water Temp Gauge Not Working
When starting the engine when cold the needle doesn't move at all when driving.
When starting the engine when hot the needle will rise up to about a quarter and then just fall down to its starting position.
Does anyone know what might be causing this?
Old May 7, 2006 | 05:05 PM
Rab's Avatar
Rab
Fucking superstar........
Have you tried replacing the coolant temperature sensor?
Old May 9, 2006 | 10:29 AM
SassyRS's Avatar
SassyRS
Little Miss...
mines doing this atm aswell..
Old May 9, 2006 | 04:04 PM
xr-stu's Avatar
xr-stu
the senders are only a few quid mate, they screw into the head to the right hand side of the exhuast manifold.
Old May 9, 2006 | 06:23 PM
JohnnyT2's Avatar
JohnnyT2
Where can i get a sender from?
Would one from a scrappy do, or am i better off buying new.
Are they the same throughout the mk2 fiesta range or are they exclusive to the xr2?
Old May 10, 2006 | 09:49 AM
xr-stu's Avatar
xr-stu
theyre all the same mate, id imagine most fords pre 1990 use the same sensor. you'll get one from a motorfactor, no point getting on from a scrappy as theyre cheap as chips new anyway, you know youre not getting a duff that way aswell!
Old May 10, 2006 | 10:48 AM
EssexBoyRacer's Avatar
EssexBoyRacer
defo faulty sensor me thinks. I've had 2 of these pack up on cars i've owned doing exactly the same thing as you've described.
manuel boeckx
13
Oct 3, 2015 02:29 PM
Harryh24
Aug 26, 2015 07:50 PM
Kop2381
Aug 23, 2015 01:17 AM
David Potasnick
Ford Fiesta
Aug 22, 2015 10:54 PM
