Cossie cambelt tension?
Old May 5, 2006 | 01:34 PM
plynchy's Avatar
plynchy
Default Cossie cambelt tension?
Just a quickie. In the process of refitting my cambelt etc, as a rough guide am I right in thinking that the tension is somewhere near if the belt can just be turned through 90'??
Will get a tension checker from work tonight to make sure.
Old May 5, 2006 | 01:36 PM
Neil S's Avatar
Neil S
That's what I've always done, I think I asked on here once and was told this was fine by Stu.
I'm still waiting for this fecking steering rack by the way!!
Neil.
Old May 5, 2006 | 02:12 PM
Dave Henshall's Avatar
Dave Henshall
as above, 90 deg on the longest run...
Old May 5, 2006 | 03:05 PM
Kevin B's Avatar
Kevin B
... and tension clockwise
Old May 5, 2006 | 03:07 PM
plynchy's Avatar
plynchy
Wot?
Neil, i'm all but done, just waiting on getting some decent gasket sealant, will now get finished and running next week I guess.
At least i've got the FRS to go to work in though, almost makes up for a sunny Friday nighshift.....then again, does it bollox.
Old May 5, 2006 | 03:41 PM
jon@work's Avatar
jon@work
Wot?
If you turn the tensioner anti-clockwise to tighten, the belt may catch on the thermostat housing
Old May 5, 2006 | 08:22 PM
king of bling's Avatar
king of bling
Default 90
90 deg is what ive always set them at paul even on cvh turbos.
Old May 5, 2006 | 08:27 PM
Damo V's Avatar
Damo V
Make sure you check belt tension at cold and after fitting belt, rotate crank twice fully clockwise, then 1 full turn anticlockwise.
Personally I wouldnt like it so the belt could be turned a full 90 degrees
70-80 degrees for me
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
