Next batch of blue screen monitors...
Old May 5, 2006 | 12:12 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Default Next batch of blue screen monitors...
...these will be in next week, so anyone that was waiting for them to turn up to place an order, should contact me ASAP, as they usually sell out fast .
http://www.randbmotorsport.co.uk/sho...?ProductID=294
Old May 5, 2006 | 12:46 PM
Stu @ M Developments's Avatar
PassionFords Creator
I wouldnt personally have a Marelli managed YB without one of these in the dash.
Old May 5, 2006 | 01:09 PM
Ryan's Avatar
Ryan
Old May 5, 2006 | 02:14 PM
MONSTER's Avatar
MONSTER
Can you put me down for 1 please Mike?
Old May 5, 2006 | 02:22 PM
Dave Henshall's Avatar
Dave Henshall
is there the escos ashtray fitment available also....?
Old May 5, 2006 | 02:47 PM
Mike Rainbird
Caraholic
Hi Dave,
The Escort ones are all avaialble in the Ashtray fitment . Green is on the shelf, blue is available next week + 1 week contruction time .
Old May 5, 2006 | 03:12 PM
coooooooooooookiiiiiiiiiiiiiieeeeeeeeeeessssssssss sssssssssssssssss!
Old May 5, 2006 | 04:45 PM
Dave Henshall
are they the same price mike ( the escos ones that is ) ? in green
Old May 5, 2006 | 05:30 PM
silky16v's Avatar
silky16v
Get on That!
shall be installing 1 of these on nest months shopping list
thank STU for the recommendation
Old May 5, 2006 | 05:42 PM
warleydaddy's Avatar
warleydaddy
Wouldnt leave home with out mine!!!!!!!!!!!!
Best thing ive brought for a LONG time!!!!
Pete...
Old May 5, 2006 | 07:30 PM
Mike Rainbird
Caraholic
The only difference in price is the blue screen ones, which are Ł10 extra .
Old May 5, 2006 | 08:06 PM
Kevin Sharp's Avatar
Kevin Sharp
is this a for sale post?
Old May 5, 2006 | 08:14 PM
I will fire this at you on Mikes Behalf....
Banner traders are allowed a for sale advert in General Discussion.
Old May 5, 2006 | 08:15 PM
Kevin Sharp
PMSL ok stu i accept the
i havent read the rules
Old May 5, 2006 | 08:16 PM
The Sludge's Avatar
The Sludge
garibaldi
they look nice
do they come with a FREE cossie
Old May 5, 2006 | 08:28 PM
Mike Rainbird
Caraholic
Kev in yo ass
Originally Posted by the sludge
they look nice
Yes, but that is the limited edition Ł15,000 one .
Old May 5, 2006 | 09:49 PM
cosworthist's Avatar
cosworthist
Default coilpack version HT leads
Evening Mike, do you have any HT leads for the coilpack version for sale?
If positive,how much including p&p.
Thanks Daniel
Old May 5, 2006 | 11:10 PM
Dunccoss's Avatar
Dunccoss
mike have they got the same features as a green one thats about 2 years old, reason being if i wanted to swap mine over whould i have to swap the wiring loom or whould it just un plug from one and fit the other, cheers dunc
Old May 6, 2006 | 08:29 AM
MATCOS's Avatar
MATCOS
Does anyone have any pics of the Escos ashtray fitment please as this sounds like just the thing I am after
Mike-now you have taken over the distribution of these-will we deal through you if a fault develops on one of these new ones ?
Old May 6, 2006 | 06:24 PM
Mike Rainbird
Caraholic
Just plug in, so you can use your existing loom. If you look at Pete's display above, that is the current one.
That has been the case for almost a year now .
Old May 6, 2006 | 07:00 PM
costina's Avatar
costina
Live long and prosper!!
Can someone tell me ?
Mine say's i'm peaking at 18.1 psi but only using a 2 bar map
is this accurate? what will it go up to?
I'm running light greens
Old May 6, 2006 | 07:02 PM
Damo V's Avatar
Damo V
IIRC there are MAP sensor settings arent there??
Old May 6, 2006 | 07:04 PM
Damo V's Avatar
Damo V
uot;]:
I had a fault with mine (Łcuked chip, it was 2 years or so old) this time last year and ultimately Mike got it sorted for me for the princely sum of Ł30
costina's Avatar
costina
Yes there is but my sensor is a 2bar so thats what its set on
Old May 6, 2006 | 07:09 PM
puddy's Avatar
puddy
What is the max boost it will read?
Thought they only went up to 28psi?
puddy
Old May 6, 2006 | 07:15 PM
costina's Avatar
costina
Seen 29.2psi on a 3 bap map when running greys in my tina
But the max is what i'm trying to find out too
somebody tell us please
Old May 6, 2006 | 07:23 PM
Damo V's Avatar
Damo V
28-30psi max
Old May 6, 2006 | 07:26 PM
costina's Avatar
costina
So the max is actually what the map sensor is?
ie 2 bar 14.5 psi
3 bar 29 psi
is this correct?
Old May 6, 2006 | 07:27 PM
Damo V's Avatar
Damo V
ie 2 bar 14.5 psi
3 bar 29 psi
is this correct?
That would be logical but I dont know for sure sorry
Old May 6, 2006 | 07:33 PM
Mike Rainbird
Caraholic
Even if your boost registers above what the MAP sensor can "see", the SECS monitor will only display what the MAP sensor can read up to (which is also all the ECU sees) and is what-ever the MAP sensor range is. So although the MAP sensor is stated as being 2 or 3 bar, you have to first subtract 1 bar (absolute) from that figure to realise what the sensor will read up to. Typically it is around 18psi for a 2 bar and 30psi for a 3 bar.
So say your turbo boosted above those pressures in the mid-range, then the SECS monitor won't display a higher figure, because it only sees what the MAP sensor sees, so the peak figure shown will only ever be what-ever the end of the range is on the MAP sensor (which again is also what the ECU will be seeing).
The way round this for fuelling is that the a/f ratio curve is extrapolated and fuel and ignition figures put in to the EPROM based on this.
Old May 6, 2006 | 08:41 PM
maxest's Avatar
maxest
Would like to see pics too!!
Old May 6, 2006 | 08:44 PM
Mike Rainbird
Caraholic
I think I have some on my computer at work .
Old May 6, 2006 | 09:01 PM
abdr500's Avatar
abdr500
maxest
i second that
Old May 6, 2006 | 09:12 PM
MATCOS's Avatar
MATCOS
Well dont just sit there go and get them
Theres a good few potential customers on this thread already
Old May 6, 2006 | 09:13 PM
Damo V's Avatar
Damo V
There atre pics on this BB somewhere....
Old May 6, 2006 | 09:15 PM
Damo V's Avatar
Damo V
Old May 6, 2006 | 09:16 PM
Damo V's Avatar
Damo V
Thats Phil (IMA)'s car above
Redkop also has hers there
Old May 6, 2006 | 09:20 PM
MATCOS's Avatar
MATCOS
Nice one Damo
Old May 6, 2006 | 09:26 PM
Damo V's Avatar
Damo V
davecos4x4's Though that looks like the older type which is slightly smaller than mine/the current
Old May 6, 2006 | 09:32 PM
MATCOS's Avatar
MATCOS
Cool great pic that last one cheers again
