oil found here in turbo now!! is it definatly turbo going??
Old May 4, 2006 | 10:04 AM
paceo's Avatar
paceo
Default oil found here in turbo now!! is it definatly turbo going??
hi guys can you please click on the link to view pictures.
http://www.fiestaturbo.com/forums/vi...320696#1320696
right just starting to dismantle my fiesta rs, ITS BLOODY HOT OUTSIDE!!
and taking this pipe off there was oil lying in here where my finger is pointing to, little puddle of it
is this defiantly indicating the turbo is going? also in previous posts when i took the crossover to intercooler pipe off where the dump valve is, there was quite a bit of oil forming here. BUT THERE IS HARDLY ANY PLAY IN THE SHAFT ITSELF?
i have changed the stem seals and cleaned out the breathers and am starting to get a puff of blue smoke creating as well when i revv up! psi was 150 across all cylinders as well.
many thanks guys!
Old May 4, 2006 | 10:13 AM
rstoughy's Avatar
rstoughy
Are you running a standard airbox?
if so it could be the engine breathing heavilly and sucking the oil through
Old May 4, 2006 | 10:23 AM
paceo's Avatar
paceo
yes i am running a standard airbox.
rob
Old May 4, 2006 | 10:25 AM
rstoughy's Avatar
rstoughy
Is there any sign of oil in it?
Old May 4, 2006 | 10:26 AM
paceo's Avatar
paceo
do you mean when i take the panel filter off? oil below there? if you mean that then no there isnt.
regards
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
jaimesdna
Aug 25, 2015 06:59 AM
track.focus'd
Aug 12, 2015 05:53 PM
