Sapphire Cosworth boot vent thingys?
In the boot of a Saff there are 2 vents one either side which i'm guessing would have once upon a time had some sort of filter in?
Mine are just 2 black plastic grills and as per usual exhaust fumes are entering there.
Are the filters or whatever was there still available or can anyone suggest a simple way of sealing these up as i do not wish to remove the rear bumper to remove the plastic grills.
Cheers Spadge...
Cheers Spadge...
like any car, they form part of the pressurised cabin ventilation system
without them in place, the cabin will not be pressurised by the blower, so as you are discovering it leads to exhaust fumes coming in.
As above Spadge they should have rubber flaps on them.
bought some last year and i think they were around Ł5 each.
had to pull the bumper off to fit them though. Could get the O/S one done but needed to either take the exhaust or bumper off to get the N/S done and the bumper was eaisiest
Originally Posted by boost mad
i wouldnt seal them up, i think they let out when u close door.... if you slammed the door there will be alot of pressure against the windows
waits to be corrected
3dr cossie
11
Dec 21, 2015 03:38 PM
lukeeboy149
Aug 22, 2015 04:29 PM
