black escort cosworth big turbo stage 3 k reg.cheap NOW SOLD
Old May 3, 2006 | 08:27 PM
fordsportjay's Avatar
fordsportjay
Default black escort cosworth big turbo stage 3 k reg.cheap NOW SOLD
for sale and priced for a quick sale.i have got a straight black large turbo escort cosworth,k reg.car has covered around 10000miles and has full service historyand all previous mots.even has aprintout from the dvla showing all old owners with photocopies of all old v5 docs.will come with a full mot.the car has the cloth hexagon trim,which i prefer to leather and its in great condition.
engine-wise i know it is stage 3-greens,3 bar,chipped and running about 22psi.has new roose boost hoses and k&n group a air filter,also has bailey header tank,swirl pot and breather kit.also had a clutch within last 12 months.not sure about any rebuilds yet as i have got to look through the history file tonight.i know it has recently had 2 lower arms,front wheel bearings and front shocks(standard,genuine ford items)
has standard alloys ,x-drilled discs-usual escos stuff.cat 1 alarm.
starts on the button and drives well.bit harsh as it is on vibratech mounts.a nice car overall ,no rust on arches etc,tiny bit under spoiler on boot lid but minimal.
best thing about this car is the price-i will take £10500 for a quick sale.may consider another cossie 3 door/sapphire in p/x if the price is right-mine is not expensive so i wouldnt expect yours to be overpriced.may even consider any other car.-again if the deal is right.
ive just took some pics but its a bit dark so you cant really see it but ill post them anyway and get some better ones tomorrow.
photobucket.com/albums/e197/jjperformance/jjperformancecars522.jpg[/IMG]
Old May 3, 2006 | 08:32 PM
fordsportjay
also has the vecta immobiliser and the clutch was done in sept 2005.it has also recently been serviced/set up by motorsport developments with silkolene pro-s oil and iridium plugs.9 owners.
cheap car!!!
Old May 3, 2006 | 08:54 PM
Sticky.'s Avatar
Sticky.
Has he swapped it for his old white saph Jay?
Old May 3, 2006 | 09:01 PM
fordsportjay
yes he has got his sapphire back paul,he really missed that car.
Old May 4, 2006 | 06:52 AM
Mr RS500's Avatar
Mr RS500
Old May 4, 2006 | 08:52 AM
fordsportjay
Old May 4, 2006 | 09:19 AM
Dirty Harry's Avatar
Dirty Harry
Super Moderator
Old May 4, 2006 | 10:05 AM
Damo V's Avatar
Damo V
circa 10,000 or 100,000 (I'm not buying jus clarifying for others )
Old May 4, 2006 | 11:10 AM
fordsportjay
sorry 100k miles
Old May 4, 2006 | 11:14 AM
Csm's Avatar
Csm
Old May 4, 2006 | 11:16 AM
MadMac's Avatar
MadMac
If only I had 10k, don't see many black ones
Old May 4, 2006 | 12:19 PM
Sticky.'s Avatar
Sticky.
This car is from are local Cheshire meet and is a little minter with all the jobs that needed doing put right.
Good luck with the sale Jay
Old May 4, 2006 | 02:39 PM
fordsportjay
some more pics-it also has samco coolant hoses and an alloy radiator.its a nice car
the car was at santa pod on the cheshire group stand.
the only things i can see that req doing at some point is an oil leak-suspect front diff oil seal and the engine mounts are a bit"harsh" but thats is up to the buyer.the front hockey sticks are in the car as one side has broken at the bottom
going to get it on the ramp after and have a look.
Old May 4, 2006 | 03:57 PM
Paddy's Avatar
Paddy
Legend
Lovely looking car and topic edited
Old May 4, 2006 | 04:26 PM
fordsportjay
thanks paddy
Old May 4, 2006 | 04:59 PM
tregmatt's Avatar
tregmatt
that is 1 cheap motor good luck with the sale
Old May 4, 2006 | 06:16 PM
E.C.H.A.S's Avatar
E.C.H.A.S
Hello mate
looks a real mint car
just one thing is it HPI clear
And has it has any pannels changed
Old May 4, 2006 | 06:52 PM
RSKim's Avatar
RSKim
This is a MINT cossie, knew he wanted his saffy back, but didnt think he'd actually go through with it pmsl someones gonna get a bargain
Old May 4, 2006 | 07:35 PM
fordsportjay
hpi clear and all original panels.
Old May 5, 2006 | 10:32 AM
fordsportjay
OIL LEAK UPDATE;
right ive just had it up on the ramp and cleaned it off as best as i could and found 2 definate oil leaks;
1 power steering rubber pipe was leaking and has been for a long time-NOW FIXED THANKS TO A JUBILEE CLIP.
2.oil return from breather kit that returns the oil to the sump had come off due to whoever originally fitted it hadnt put it on right as the hose was too short and only just went on about 10mm.can you imagine how much oil would come out of a)the return pipe and b)blowing out of the sump.
NOW FIXED WITH A NEW,CORRECT LENGHT PIECE OF HOSE.
also the pipe from the original breather to the bailey tank was kinked and has now been re-routed.
now im pretty sure that these are the main sources of oil leaks,especially as i think the oil pipe has been leaking since it had the clutch fitted in sept 2005.
only time will tell and i dont expect it to be completely oil free as all 4x4 cossies(well all cossies) leak oil unfortunatelybut im pretty confident to say it will be no worse than any other one now.
Old May 5, 2006 | 03:16 PM
KSA-Cossie's Avatar
KSA-Cossie
Very nice escos jay m8.
Old May 5, 2006 | 03:18 PM
fordsportjay
cheers matey
Old May 5, 2006 | 03:24 PM
Kiwi_Cossie's Avatar
Kiwi_Cossie
Jay, did you find out if it had had any rebuilds done?
Old May 5, 2006 | 04:16 PM
fordsportjay
there is nothing in the history about rebuilds but had the head done in 1999/2000.very good oil pressure.
Old May 5, 2006 | 07:20 PM
fordsportjay
got someone coming to view it in a short while-should be gone hopefully at this money!!!!!
Old May 5, 2006 | 09:26 PM
fordsportjay
CAR NOW SOLD -
Old May 5, 2006 | 09:50 PM
cosstu's Avatar
cosstu
Escortdriver1
Jul 31, 2015 02:36 PM
Old ford
Jul 31, 2015 06:50 AM
