Help identifying cossie cams.................
May 3, 2006 | 08:24 PM
need help identifying some cossie cams they are marked.....
YNOO11 LYD2
AND
YNOO11 LYD4
ARE THESE JUST STANDARD???????
May 3, 2006 | 08:25 PM
The YN0011 bit is on one side of the cam and if you spin if over the LYD bit is on the other ........
May 3, 2006 | 09:10 PM
May 3, 2006 | 10:02 PM
May 4, 2006 | 10:42 AM
May 4, 2006 | 10:49 AM
From: Under the water.... .......in a nuclear submarine
I'll have a look at mine when i get home, i've got my cam cover off
May 4, 2006 | 10:50 AM
cheers
May 4, 2006 | 06:22 PM
May 4, 2006 | 06:48 PM
Standard 4x4 cams
Inlet YN0011 & LYD 2
Exhaust YN0011 & LYD 5
Hope that helps
May 4, 2006 | 09:34 PM
mmmmmmmmmmmm so i wonder if 1 = 2wd n 1 = 4x4
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
