How do you tighten motor bike spokes??????
Old May 2, 2006 | 02:54 PM
CraigJ's Avatar
CraigJ
Default How do you tighten motor bike spokes??????
ive got a dtr125 field bike and the rear wheel spokes have started to come loose just wondering if i can tighten them or does it need to be taken to a bike shop?
Old May 2, 2006 | 02:57 PM
bud-weis's Avatar
bud-weis
Football Cwazy
you put the lime in the coke, you nut
haven't a clue, but my old bmx just used to twist the spokes with some pliers
Old May 2, 2006 | 03:00 PM
jumpin jack crash's Avatar
jumpin jack crash
its a gas gas gas
need a spoke key for a start, then just find the shit part of the rim which needs tightening work out which side the buckles on and tighten the other side.
well thats how i do them on the mountain bike and im guessing its the same philosophy for a moto-x bike too.
if that fails then take it to a shop
Old May 2, 2006 | 03:03 PM
CraigJ's Avatar
CraigJ
how much are the spoke keys?? will bike shops stock them or are they sumat i need to order
Old May 2, 2006 | 03:10 PM
jumpin jack crash
its a gas gas gas
not too sure to be honest, u might get away with using a set of plyers as there motorbike spokes they be thicker than mtb ones. if not they should sell them in shops
Old May 2, 2006 | 03:28 PM
joel_winders's Avatar
joel_winders
spoke keys are about Ł12 quid for a gudden !
Old May 2, 2006 | 03:40 PM
89xr2's Avatar
89xr2
Brap!
Its like a little spanner for a motorbike. Just look online for a wheel building/straightning guide and follow it. principles are the same for motorbike and push bike but motorbike wheels are obviously alot harder to straighten as the rims are alot stronger.
Old May 2, 2006 | 03:55 PM
richj's Avatar
richj
When you do it only tighten up every third one this will stop the wheel from buckling, eventually after going round the rim 3 times all the spokes will be tight. Dont just tighten the loose one it will pull the rim out of line
Old May 2, 2006 | 04:09 PM
CraigJ's Avatar
CraigJ
cheers
bobsworth
77
Mar 24, 2016 09:30 PM
gambo08
Feb 4, 2016 10:49 PM
sridgett
Oct 1, 2015 07:30 PM
rsguy
44
Sep 29, 2015 03:29 PM
