Anyone tried orginal amp.& coil with Autronic or corresp
Old May 2, 2006 | 02:15 PM
matsin's Avatar
matsin
Default Anyone tried orginal amp.& coil with Autronic or corresp
hi
I'm building a sierra cosworth -91 with Nira I3+ (swedish, Autronic like) aftermarket ems. Now to the problem:
I'm going to use original amp. and coil and now I wonder how should I connect the amplifier to my EMS. I have tried to ground the signal ground from amp. And the signal to my ignition out. It won't work, no spark (only 3,4volt over the pins).
If I use the standard ecu and connecting 24/25 (signal gnd and signal)I get a spark (5volt over pins).
So, have anyone used original amp and coil. How did you connect the 2 cables from amp to aftermarket ems?
With standard bosch amp they have only one trig cabel and common gnd.
/Andre'
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
15
Oct 7, 2015 03:43 PM
A.t.p
Sep 29, 2015 05:04 PM
