Where Can I Get A New One From?
May 1, 2006 | 07:11 PM
Where can I get a another water pipe outlet for my T3 from?
Thanks
Dan
May 1, 2006 | 07:42 PM
i got one from ford,only place that did it...bout Ł40 if i remember right
good old ford eh!
May 1, 2006 | 07:48 PM
If there the only place anyone have one from a broken T3?
Thanks
Dan
May 1, 2006 | 08:06 PM
May 1, 2006 | 08:15 PM
Why do you say to run it without water?
Thanks
Dan
May 1, 2006 | 08:19 PM
well think about it how hot does the turbo get to
and where does that water go back into
May 1, 2006 | 08:23 PM
Cool!
Are there any advantages to running water through it?
Do you run water through yours?
Thanks
Dan
May 1, 2006 | 08:28 PM
i dont on mine or any of the other cars i have. running water though it just cools the oil down and pro long the turbo life but imo its better to run with out it but all rst have oil coolers on there car,
May 1, 2006 | 08:34 PM
Cheers for the advice!
Looks like I have saved myself money from replacing the water pipe
but may have to go towards another turbo
Thanks
Dan
May 1, 2006 | 08:44 PM
was going to say it look a bit worse for ware!!!
May 1, 2006 | 08:47 PM
There is no play in the shaft but I must say that the photo makes it look alot worse than normal.
May 1, 2006 | 08:56 PM
