what is this wire for on my pectel style loom???
May 1, 2006 | 12:27 PM
i have a motorsport wiring solutions loom & need to know what the blue wire is for in the pic below???
BLUE & WITH
ISS STAMPED ON IT
anybody know?
Intercooler Spray System.....
May 1, 2006 | 12:28 PM
OOh David you cheater....
May 1, 2006 | 12:56 PM
water injection you mean?
cheers
May 1, 2006 | 12:57 PM
Water injection for a P8.
May 1, 2006 | 12:58 PM
yes will be connected to ecu pin 12
May 1, 2006 | 05:40 PM
May 1, 2006 | 05:54 PM
no , its intercooler spray system as ian said, not for WI, these are both differant.
May 1, 2006 | 05:56 PM
i would bet it's used for water injection even though it's labelled iss, check which ecu pin it comes from....
May 1, 2006 | 05:59 PM
Quote:
you are right of cause,, one squirts water into the intercooler,, the other onto the intercooler!
but most people will use this are the water injector trigger on a road car
May 1, 2006 | 06:00 PM
Why on Earth would you want water injection on a ROAD car?
May 1, 2006 | 06:03 PM
Quote:
poor intercooler efficency,, wrong size turbo
there many reasons
May 1, 2006 | 09:04 PM
its for water injection . you would connect it to the earth side of the pump relay and live side of the relay to same feed as the ecu as when you shut the ecu off the pin outs earth
May 1, 2006 | 09:06 PM
Quote:
ya something like this
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
muz
Sep 30, 2015 08:29 AM
jay030787
Sep 25, 2015 01:38 AM
