Brake bias on big brake escos
Old Apr 30, 2006 | 09:30 AM
MATCOS's Avatar
MATCOS
Default Brake bias on big brake escos
I now have 355mm fronts and 300 rears- as the rears are bigger and I assume more powerful do these effect the brake bias at all, ie if I brake really hard will I;
A-Get forced into the seatbelt and my eyes pop out?
B-slide sideways for 100ft before coming to rest in a ditch?
I havent driven it yet with both front and rear and wondered if any changes need to be made before I do?
Old Apr 30, 2006 | 10:07 AM
big-dirty-dog's Avatar
big-dirty-dog
even from standard the fronts allways do the most of the braking anyway about 70% 30% or something like that,i wouldnt be to concered but i maybe wrong good luck
Old Apr 30, 2006 | 10:53 AM
Dunccoss's Avatar
Dunccoss
that is what i had on my escort befor i upgraded and you wont have any problems mate as long as all is working fine it will stop very well in a straight line with the abs working over time its great. Just bed them in well then find a nice wide empty road and slowly go faster just to make sure, mine pulled up very well from 172 mph many times
Old Apr 30, 2006 | 03:12 PM
Mr C's Avatar
Mr C
You should have no problems as you have upgraded the fronts massively too, I would check they work correctly 1st time out on a private road just to be sure too
The rears got bigger calipers? 4pots or std?
Old Apr 30, 2006 | 06:45 PM
MONSTER's Avatar
MONSTER
If you havn't changed the calipers then they should be spot on, mine are & its the same set up as yours
Old Apr 30, 2006 | 07:52 PM
MATCOS's Avatar
MATCOS
Still standard calipers - they are Duncos's old 300mm discs before he upgraded
Sp3no
Sep 27, 2015 07:23 PM
IainRS1700T
Sep 25, 2015 06:44 AM
focus2351
Sep 9, 2015 09:33 PM
cossirob
Sep 3, 2015 09:17 PM
