big brakes
Old Apr 29, 2006 | 09:18 PM
scott-cos's Avatar
scott-cos
Default big brakes
hi folks. ive just fitted my 18inch rondells today but the brakes look tiny behind the wheels. what big brake upgrade would you recommend for the frt and rear and rough prices please.
thanks scott
Old Apr 29, 2006 | 10:39 PM
thedaddie's Avatar
thedaddie
how much do you want to spend?
get some pics up of your car with the new alloys
Old Apr 30, 2006 | 07:15 AM
wimwerf's Avatar
wimwerf
it also depends how you gonna use the car...only road...or road/track sometimes...or a lot of track..
Old Apr 30, 2006 | 08:17 AM
Gordon1's Avatar
Gordon1
Hi spec 335mm 6 pots about £1200
Old Apr 30, 2006 | 10:56 AM
Dunccoss's Avatar
Dunccoss
give martin a ring and get some 355, 6 pots APs mate you carnt go wrong with them, will cost a little bit more than hi spec but better and also be worth more if you want to sell them latter on
Old Apr 30, 2006 | 11:13 AM
maxest's Avatar
maxest
And get a big disc kit for the rear using standard calipers....
Old Apr 30, 2006 | 07:11 PM
scott-cos's Avatar
scott-cos
here is pics of the new wheels
car is only road used
Old Apr 30, 2006 | 07:49 PM
S1rst's Avatar
S1rst
Old May 1, 2006 | 08:17 AM
Malc50's Avatar
Malc50
Hi Scott
The car looks
Cheers Malc
Old May 1, 2006 | 11:38 AM
wimwerf's Avatar
wimwerf
only road used..then 4pots 330mm a good enough...
Old May 1, 2006 | 02:04 PM
scott-cos's Avatar
scott-cos
where is the best place to order from.
Old May 1, 2006 | 02:13 PM
ian rst's Avatar
ian rst
What suspension have you got on that mate?
Old May 1, 2006 | 02:37 PM
scott-cos's Avatar
scott-cos
its koni adjustables. not sure how much its been lowered.
scott
Old May 1, 2006 | 06:42 PM
scott-cos's Avatar
scott-cos
what would be better brembo brakes or ap brakes
Old May 2, 2006 | 02:49 PM
ian rst's Avatar
ian rst
I have just bought some brembos but not on yet, AP's are meant to be the best but i couldnt afford them.
Old May 2, 2006 | 02:57 PM
Chris Honeywell's Avatar
Chris Honeywell
True m8 but for about another £200 u get 6 pot calipers, 356mm discs
and they are also 4 mm wider
If your gonna buy a set get it right 1st time and get the biggest you can afford
Old May 2, 2006 | 06:12 PM
scott-cos's Avatar
scott-cos
what kind of brakes are they. also where from
thanks scott
Old May 2, 2006 | 06:55 PM
thedaddie's Avatar
thedaddie
how much diffence in braking is there between the 330mm 4 pots and 356mm 6 pots?
Old May 8, 2006 | 06:50 AM
Chris Honeywell
I changed from 330mm 4 pots to 356mm 6 pots APs,
they both work like you would not believe
I actually found the 6 pots to be not quite so sharp and more progressive
but trust me you will never run out of braking
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
