What Brakes You Using?
Full 2wd setup
4 Pots on the front
Disc conversion on the rear
Bought it a couple of years ago, paid about Ł350 for the whole lot, inclusive of 2 front hubs with driveshafts, complete braided brake lines to replace the standard ones, and a near on brand new servo.
4 Pots on the front
260mm fronts with standard turbo calipers
253mm non vented rears with sierra rear calipers.
Stops like fffoooooooooooookkkk !
Front discs cost me about Ł14 each
Don't ask - I don't know
Originally Posted by notSteveS2
Front ... cossie 2wd duscs with 4x4 calipers...
standard rears!
braided lines all round
standard rears!
Originally Posted by Freddy_mercury_magic
Rob you dont need a major upgrade for the power you got, Just bigger discs and a good pad set up,It'll see you well enough for 200bhp
I heard from sum1 thaht has st170 set up on 1 car and cossie set up on another that they prefer cossie set up...
make sure if u do disc conversion on rear u get bias valve...
or u cud end up with dangerous brakes
oh yea cool...
yea im not sayin st170 aint gd... they must b gd or they'd b removed... but i was told he prefered the cossie brakes...
wierd how sum ppl have probs with lockin up n sum dont even tho they dont use bias valve...
ne1 no y?
ne1 no y?
ne1 no y?
ne1 no y?
Can he stiffen his front suspension ?
As he brakes its possibly transfering weight forward..... thus lifting the back and losing traction... try it with 2 people sat in the boot
oh yea cool...
ne1 no y?
ne1 no y?
Focus ST170 300mm front conversion
Standard rear.
Stops nicely. The rear brakes do so little of th eoverall braking effort I see no reason to dick about with the setup.
ABS has been filed away in the bin as well
Standard rear.
Originally Posted by Smiggy
I use this
this
quite a bit of this
and a whole load of these
PMSL !!!
I find this set up particulary effective in the wet!
Hope this helps
SMG
this
quite a bit of this
PMSL !!!
Hope this helps
SMG
