17in alloys on a zetec s
Old Apr 24, 2006 | 08:10 PM
johno's Avatar
johno
Default 17in alloys on a zetec s
hello there wondering if sum1 cud help me out if i put 17in alloys on my zetec s will it sit high over the alloys or will it need lowering etc cheers if u can help wiv sum advise
Old Apr 25, 2006 | 06:34 AM
Phil DJ's Avatar
Phil DJ
Chances are it will sit quite high. Problem is that if u lower it the tyres might catch on the arches so u may need to do some adjustments there
Old Apr 25, 2006 | 06:47 AM
sexy xr2i's Avatar
sexy xr2i
if lowered def rub with 17inch!!! my sis put 15s on standard corsa didnt look as bad as i thought,so i would of though 17 might sit nice and fill up the arch!!! but havent tried so dont know for sure!!!!someone will know 4 sure x
Old Apr 25, 2006 | 12:06 PM
mikey109's Avatar
mikey109
Mines is lowered 40mm on pi springs and with my 17's doesnt rub at all. Only catches occasionally with two ppl in the back. Make sure you have Falken ZE512 205/40/17 tyres and u will be fine. Its a bit of a hit and miss tho, check out www.zsoc.com if u wana look further into it as sum zetec s' rub and some dont. Best of luck mate.
Old Apr 27, 2006 | 05:33 PM
johno's Avatar
johno
Default thanx
mikey109 thanx for the advice gonna try 17s on her sunday shud b good thanx again yeh
Old Apr 27, 2006 | 05:42 PM
Oranoco's Avatar
Oranoco
Stick to a 16" wheel and avoid Falken tyres unless you want to go ditch finding. Falken ZE502 and the ZE512 are pants. You should buy tyres on how they perform not for giving clearance because you've put wheels on that are too big for the car
Old May 2, 2006 | 08:42 AM
mikey109's Avatar
mikey109
I've had falkens on my car for over 2 years and never had any problems with them at all. U will only go ditch finding if you drive outwith your own capabilities mate.
Old May 2, 2006 | 04:26 PM
Oranoco's Avatar
Oranoco
mikey109 use a decent tyre and then comment mate.
I thought my ZE502's were awesome so got ZE512's when they wore out. Couldn't get them again as they only had three so got Yoko A539's which are a tyre I don't overly rate but they stand head and shoulder over the Falken tyres.
Old May 2, 2006 | 05:45 PM
mikey109's Avatar
mikey109
Well thats my opinion mate and last time i checked i was entitled to it. They do the job for me well so just passing on to some1 who asked for advice and how to get 17's onto there car so i told them. No1 asked about tyre opinions until u popped up.
Old May 2, 2006 | 06:17 PM
Oranoco's Avatar
Oranoco
Wind your neck in mate.
You advised a tyre choice which in my opinion/experience (and my fathers, who incidentally has 40 years of tyre research experience behind him) is naff. I advised against this just the same as I would with any naff suggestion. Tyres are the only contact between you and the road therefore fitting decent good quality ones is of paramount importance.
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
