cossie clutch?
Old Apr 21, 2006 | 09:45 PM
shanemc's Avatar
shanemc
Default cossie clutch?
i think the clutch in my 2wd cossie is giving up the ghost.what would be the best replacement,the car is stage 3 spec,peaking 25psi approx 330brake.
any suggestions appreciated,thanks.
Shane.
Old Apr 21, 2006 | 10:53 PM
cossie604's Avatar
cossie604
A AP (or any other non techni-clutch fast road item) fast road/organic clutch kit would be spot on IMO....not as harsh as a paddle which is also not needed for your power levels. Im gonna be running a AP racing organic on my T35/Greys set up...had enuff of paddle clutches in the past.
Stu
Old Apr 22, 2006 | 10:26 AM
cozzie4d's Avatar
cozzie4d
Might also be an idea to go for the 6paddle, I think it depends on your future plans
Old Apr 22, 2006 | 01:18 PM
shanemc's Avatar
shanemc
Stu
what are the paddle clutches like to use on the road?its a not an everyday car so i wouldnt really mind if it'll be a bit harsh so long as it'll stand up to some abuse.would a paddle with a std cover be a good all rounder,or should i just go for the ap organic with heavy duty cover?
sorry for all the questions.
cheers,
Shane
Old Apr 22, 2006 | 01:36 PM
Mr 19"'s Avatar
Mr 19"
I use Sachs organic clutch. I have tried several different cluthes, but i think this is the best so far. Almost no judder, and i weights over in agood way so you feel when the clutch is released. Very good.
Old Apr 22, 2006 | 05:14 PM
Csm's Avatar
Csm
stay away from techni-clutch !!!
own personall experiance on this aswell as several others on here aswell !!
ive got a AP heavy duty clutch and hd cover and seems fine
Old Apr 22, 2006 | 05:18 PM
TIFF's Avatar
TIFF
Chasing Radders
Alcon 6 paddle clutch with standard cover plate.
Was fine for my 380bhp 3DR running 32psi
Old Apr 22, 2006 | 06:03 PM
Staffi's Avatar
Staffi
Old Apr 23, 2006 | 08:33 AM
Jay,'s Avatar
Jay,
Sponsor
ok i gota a sachs 4wd plate on a 2wd cover in mine done 5000 miles @2bar
Old Apr 23, 2006 | 09:23 AM
B11GNS's Avatar
B11GNS
I have an alcon 6 with a ford cover. Although i might try an organic one next time as the paddle is beginning to get on my tits!
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
