Escort cosworth splutter
Old Apr 21, 2006 | 04:53 PM
Big Man's Avatar
Big Man
Default Escort cosworth splutter
Hi guys, escort large turbo, standard, has started being silly!
takes 5-6seconds to start up, then might die, but the major problem is when your driving, the car back fires and the rev counter goes balistic, bouncing up and down, you dip the clutch and it wont rev out, afew seconds later it stops doing it! does it at any random moment 20mph 100mph any gear, when car is on or off boost!
any ideas lads?
p.s its only done it in the last week, fine for 8 months. and it take longer to fire up.
Old Apr 21, 2006 | 07:14 PM
Damo V's Avatar
Damo V
Washed it under the bonnet?
or been out in heavy rain?
My money is on the loom conectors under the N/S bonnet vent by power steering pot, they need cutting off and soldering together permanently OR crank sensor...
Old Apr 21, 2006 | 07:35 PM
cos jon's Avatar
cos jon
Yep, as damo says sounds like the loom connections (mine used to do this very random, cut the connectors out and solder together - problem sorted !)
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
