BODY PANELS
Old Apr 21, 2006 | 11:36 AM
statto's Avatar
statto
Default BODY PANELS
my passenger side wing seems to be sitting a tad high at one side, like this
does anyone know if this could be leveled out with out have to spray the car
Old Apr 21, 2006 | 12:27 PM
Gary F's Avatar
Gary F
It looks like your bonnet mate
Old Apr 21, 2006 | 12:52 PM
statto's Avatar
statto
i though that to but the gap at the top of the side light is bigger than the gap on the drivers side
Old Apr 21, 2006 | 01:00 PM
Damo V's Avatar
Damo V
Im sure there are "stops" on the slam panel, screw out the N/S one a little so the bonnet has to sit higher...
While you are at it post up some reasonably close up pics of the sealant where the wing meeets front panel on both sides clearly showing the spot welds etc... the only reason it would actually be out of place is if it had a wing at some stage..
Old Apr 21, 2006 | 01:24 PM
statto's Avatar
statto
good man, i'll try get some close up picture taken, just looks like the wing is sitting up a wee bit to high, if thats the case can it simply be straighten without having to paint
Old Apr 21, 2006 | 01:36 PM
Damo V's Avatar
Damo V
Originally Posted by statto
:if thats the case can it simply be straighten without having to paint
nope, if its had a wing, its been fitted poorly... nothing can change that I'm afraid
Old Apr 21, 2006 | 01:39 PM
statto's Avatar
statto
take it off and refit then
Old Apr 21, 2006 | 01:41 PM
Damo V's Avatar
Damo V
take it off and fit new more likely
but dont worry about that yet, get the pics up and adjust the stop first
Old Apr 21, 2006 | 01:46 PM
statto's Avatar
statto
the stopper being the bit inside the bonnet that it rests on when it's closed, yeah?
i'll try adjusting that but then there still the bigger gap between the top of the side light and that quarter panel
Old Apr 21, 2006 | 01:49 PM
statto's Avatar
statto
not a great picture but you can sort of see the gap at the top of the side light
Old Apr 21, 2006 | 01:50 PM
Azrael's Avatar
Azrael
Why do you think so?
Old Apr 21, 2006 | 03:52 PM
JHS's Avatar
JHS
Open your bonnet and take a picture of the area where the front wing meets front crossmember (?) The area above the headlight
Old Apr 21, 2006 | 04:28 PM
THE RADMAN's Avatar
THE RADMAN
just take a look at the rear edge of the wing in the door shut and see if the black vinyl wing sticker is there,it runs the full height of the wing, if not its had a new wing
Old Apr 21, 2006 | 06:47 PM
Damo V's Avatar
Damo V
We are talking about a road car here not a rally car mate, removal would mean drilling out old spots, then plug welding if re use old item, which will stand out a mile off on a car like this...
Old Apr 21, 2006 | 06:48 PM
Damo V's Avatar
Damo V
Already been asked for
Old Apr 21, 2006 | 06:54 PM
Damo V's Avatar
Damo V
statto
take a couple at this sort of distance, obviously focusing on the previously mentioned areas, take identical photos either side..
As you can see in my pics, the welds are in perfect symetry, if you have had a wing the probably wont be as good...
Old Apr 21, 2006 | 08:13 PM
JHS's Avatar
JHS
But you didt get the right picture though...
Old Apr 21, 2006 | 09:37 PM
Azrael's Avatar
Azrael
I can't see a problem in that. I mean it can be done so noone exept expert bodywork specialist looking for it will find that it was rewelded.
Old Apr 21, 2006 | 09:41 PM
Damo V's Avatar
Damo V
right whatever you say
Old Apr 21, 2006 | 10:12 PM
ozcos's Avatar
ozcos
There is such a thing as FAKE spot welds. Which we use to use on concorse cars restorations and repairs useing secondhand panels.
This is where the hole of the original spot weld is used to attach the wing and then ground flush and a fake spot weld is put beside it.
Tool used is old spot weld tip used like a centre punch.
You can't tell the difference if done correctly.
Your car doesn't need a new wing just some massaging.
You may have a different gap at the top but whats it like at the bottom of side light it may just all need realigning.
Start with bonnet, then sidelight, grille and bumper
Few were perfect from FORDS.
Mark
chowfornow
14
Jan 5, 2019 09:01 PM
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
