RS500 Plenum With Spacer
Old Apr 21, 2006 | 11:07 AM
_DAN_'s Avatar
_DAN_
Yoon
Default RS500 Plenum With Spacer
Any benefits to this?
I know you can fit a sacer to a standard plenum but what about on a RS500 one?
Old Apr 21, 2006 | 11:58 AM
Default Re: RS500 Plenum With Spacer
I run this on my motor circa 700bhp on race fuel, not sure at what point their is benefit.
Old Apr 21, 2006 | 12:00 PM
_DAN_'s Avatar
_DAN_
Yoon
I thought yours was 4 injectors?
Or have you got t'other four blanked off?
Old Apr 21, 2006 | 12:48 PM
rapidcossie's Avatar
rapidcossie
he only runs 4 injectors.
the important bit is the plenum and throttle as they are much bigger than standard
Old Apr 21, 2006 | 12:53 PM
RS500/364's Avatar
RS500/364
But was running 8 at one point i belive and that maybe the point hrod is on about i heard 1 benefit to the mapper it will need remapping
Old Apr 21, 2006 | 12:57 PM
rapidcossie
the car will need remapping if you fit the plenum spacer as there will now be more air.
rod used to run the 8 set up on his old 500 bhp engine but dont think he used the spacer then??
IMO the spacer is only worth while over 550bhp
Nov 1, 2015 06:53 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
mondeomark
Sep 28, 2015 06:28 AM
IainRS1700T
Sep 25, 2015 06:44 AM
timsrs
22
Sep 24, 2015 08:14 PM
