BIG UP Doug & Kev Sharp
Cheers Guys
Had a couple of little probs over the past couple of weeks with the rebuild of my car.
Wheel Studs
most of them £ucked, put up a post asking some advice and Doug kindly sent some that he had kicking around up within a couple of days
Outside Temp Sensor
snapped the wire on this the other night so it was the only thing stopping the bumper going back on. Again i stuck up a post asking if anyone had one. Kevin Sharp was straight back with a reply and the said sensor was waiting for me on my return from work last night
Thanks alot Guys your help has been much appreciated
Wheel Studs
most of them £ucked, put up a post asking some advice and Doug kindly sent some that he had kicking around up within a couple of days Outside Temp Sensor
big up for the boys!
that mean the escort is almost ready?
i *might* have found my problem last night! removed the fuel tank and it was in a bad shape. round the neck of the fuel filler neck there was tons of dust, dirt and rust which looked to be in the tank also. when we emptied it the fuel was dirty coloured!
also a small hole appearing on top of tank! hopefully the dirt has blocked the fuel filter causing the problem. i'll see in 2 weeks because im goin offshore today
chop
chop
Chops,
Yes the Escort is almost there. Should be ready for starting up over the weekend then it will need a bloddy good clean
Thats good that you have found some sort of indication of something around the fuel tank. Hope it sorts it out.
Have a good trip M8
Have a good trip M8
SMILER258
Sep 28, 2015 09:04 AM
