Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Mondeo brakes
Old Apr 20, 2006 | 02:05 PM
JanDK's Avatar
JanDK
Default Mondeo brakes
Anyone know about the sizes of the brakes om a Mondeo V6 and what year??
Are theese brakes simular to 4x4 cosworth brakes or??
Old Apr 20, 2006 | 10:37 PM
mondeofocus's Avatar
mondeofocus
The mondeo V6 front disc brakes are 278mm on all of the mk1 and 2 models. But Im not sure about the size of cosworth brakes, I think theyre 4 pots instead of the single piston that the mondeo has.
Old Apr 21, 2006 | 07:27 AM
JanDK's Avatar
JanDK
Thank you mondeofocus...
Cosworth´s have 278mm´s to
2WD Cos. = 4 pot
4WD Cos./Escort Cos. = singel
I think but I am a littel sure though
Old Apr 21, 2006 | 11:30 PM
mondeofocus
Am I right presuming you want to upgrade the front brakes on your mondeo?
A set of 300mm focus ST discs and calipers could be the way foward
Old Apr 23, 2006 | 07:23 PM
JanDK's Avatar
JanDK
No.. just thinking if the brakes are all the same would be easyer to buy pads and discs! I have been informed that when using MondeoV6 discs on the Cosworth a 10mm spacer is needed.
Focus RS/Mondeo brake upgrade?? hmm.. is it a straight forward and directly fit upgrade??
And if so on the Mondeo... would it be the same on the EscCos??
MondeoV6 brakes are very well I think, there fore no upgrade on this one.
If confused... i drive MondeoV6 ´95 and Escort Cosworth
Old Apr 24, 2006 | 10:59 PM
mondeofocus
That clears that one up a bit
The focus brakes are a straight swap on a mondeo so I presume youd need the same 10mm spacer.
Old Apr 25, 2006 | 07:27 AM
JanDK's Avatar
JanDK
sound very nice and easy then )
Brickhouse
14
Oct 3, 2015 07:28 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
