Cosworth Clutch Cable Question
Old Apr 19, 2006 | 11:15 AM
Dave@CarportDev's Avatar
Dave@CarportDev
Default Cosworth Clutch Cable Question
Is there any other cable available that would be a bit shorter than the standard cable to give te clutch more lift. The biting point is right at the bottom no matter which clutch I have fitted (a few have been tried)
Any help would be appreciated.
Dave
Old Apr 19, 2006 | 11:53 AM
Dave@CarportDev
BTTT
Old Apr 19, 2006 | 11:54 AM
dangerous - reyland's Avatar
dangerous - reyland
Why not speak to Martin @ Reyland for a hydraulic conversion
better feel, easier on the leg no more ford pedal box problems
Old Apr 19, 2006 | 12:03 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
what clutch and on what car mate?
Old Apr 19, 2006 | 12:36 PM
Disabled Account's Avatar
Disabled Account
Default Re: Cosworth Clutch Cable Question
Dave
Sounds like your pedal racthet/quadrant is not resetting.......or may be broken. When you change the cable, or clutch the racthet/pawl should reset to a midway/upper midway pedal position.
Old Apr 19, 2006 | 12:38 PM
R4N SS's Avatar
R4N SS
ford only do the 4x4 clutch cable now which is a bit longer than the 2wd one so is a bit easier to fit.
At least I think its longer, either that or its shorter cant remember now but there is a diff between the two and the 2wd one is no longer available.
Old Apr 19, 2006 | 01:32 PM
foreigneRS's Avatar
foreigneRS
Testing the future
think about it, a longer or shorter one won't make any difference if the inner cable is the same amount longer than the outer
Old Apr 19, 2006 | 01:40 PM
SPADGE's Avatar
SPADGE
Adjust it manually
Jack up the front of the car
Get someone to sit in the drivers seat
Get underneath with a pry bar
Get the person in the car to depress the clutch
Wedge the bar behind the clutch arm to stop it going back
Get the person in the car to SLOWLY let the pedal up until you hear a clicking noise. Let it click about 2 or 3 times.
Check the clutch now and if the pedal is still too low repeat the above until your happy!
Don't do too much at a time or youmay over adjust it!!
Spadge...
Old Apr 20, 2006 | 09:41 AM
Dave@CarportDev
Cheers for the advice guys especially SPADGE. Worked perfectly mate biting point right up near the top now
Old Apr 20, 2006 | 09:46 AM
Disabled Account
Cheers for the advice guys especially SPADGE AND Doug who diagnosed it as a ratchet/quadrent problem from the outset.......... :
Old Apr 20, 2006 | 09:48 AM
GARETH T's Avatar
GARETH T
you can buy a manaul adjusting cable kit from GGR
http://www.grahamgoode.com/cosworth/sus1.htm
jessie_rs
11
Jun 3, 2019 04:57 PM
Chas
Sep 21, 2015 08:57 PM
Anutternutter
24
Aug 31, 2015 01:24 PM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
