saff coil overs
Hello! Johnny from sweden here!If you know that you will use your car on both the road and track, you need a coilover set-up with adjustable dampers, because the car will be way to hard for road use with a setting that is for track use. As Bilsteins not are adjustable, it,s not so easy to change setting for track days. Everything depends on how much money you have. you get what you pay for here, and i would recommend a set of Öhlins coilovers if you can afford them. I guess they cost around 2300 £ here in Sweden, but they are world class with separate gas cabisters and both compression and rebound adjustment.
thanx for the info i was thinking of avo s but have heard some bad thing s about them
i just seen the new spax they look really good and and have some good settings ?
I had gaz on mine 4 5 weeks even on soft they were just too much
For on the road they are crap
Wasted money and ended putting new Konis back on after someone said they would have my old ones,then could not come up with the dosh
avo's are better
avo's are better
Nov 3, 2015 04:08 PM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
