Info required on the New Focus ST 5cyl 2.5l engine
As the title suggests.
This engine is from the Volvo S40 T5.
Does it use the volvo gearbox in the ST?
Does Volvo do a FWD inline gearbox to fit it?
Bore / Stroke etc??
Post up any info you have on this engine
Bore / Stroke etc??
let me find the link, apparently there is someone who did some testing on it before hand and it won't take more than about the 270 mark as the block isn't as thick as the volvo ones
in saying that, some places reckon they have seem mearly 300 horses out of it
its the smae block i thought,,,,,,,,volvo aint changed there block for years, the non turbos have the oil return for the turbo pre drilled and then blocked off too,,,,,,,, hence they pop the cap and leak
http://groups.google.co.uk/group/uk....137586a5bfd0f8
look at post 69 (oo-eer mrs)
i'll try and find the rest of the messages relating to it where they go into more depth
borrowed from ffoc
been told that the trouble with extracting big power from the new ST is that the motor uses inferior conrods to those fitted in the topline Volvos (are the cars called t5Rs or something?).
Allegedly (I'm only repeating this parrot fashion) but if anyone is thinking of going beyond a chip & an exhaust upgrade for a new ST then you're into the realms of having to fully strip the engine to replace the conrods. If this is true you certainly don't want to be just bolting a bigger turbo onto it!!!
the R class volvo's did push out loads of power, but anything is possible if people have the time and effort to get them done
who'd a thunk that someone would have been daft enough to put a volvo 5 banger into a focus
