Sierra RS Cosworth alloy front pulley HELP
Old Apr 17, 2006 | 09:10 PM
abdr500's Avatar
abdr500
Default Sierra RS Cosworth alloy front pulley HELP
Sierra RS Cosworth alloy front pulley Item number: 4630830803 could this be used on a cosworth was told off some one off here that you cant use it beacuse it has alloy pick up lugs could some one confirm this is true
Old Apr 17, 2006 | 09:19 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
if its all alloy you could replace the lugs with steel ones... it would be ok then. big f@@k up by whoever made it though!
bud-weis's Avatar
bud-weis
Football Cwazy
at a guess, i'd say it wouldn't work aswell because of the crank sensor being magnetised to pick up the normal pulley lug (if you get what i mean, i know but can't explain it too well )
Old Apr 17, 2006 | 09:30 PM
abdr500's Avatar
abdr500
martin-reyland
right i see but in the description he says it was running on a car i understand about how the pick up works i was told you do one is correct if yes how much is one thanks
Old Apr 17, 2006 | 09:41 PM
abdr500's Avatar
abdr500
up we go
Old Apr 17, 2006 | 09:45 PM
costina's Avatar
costina
Live long and prosper!!
They usually fit grub screws in the lugs so the sensor can pick it up
Paul
Old Apr 17, 2006 | 09:49 PM
abdr500's Avatar
abdr500
costina
grub screws does any one have any pic of one with gub screws or the screws them self
Old Apr 17, 2006 | 10:22 PM
Tony Ryan's Avatar
Tony Ryan
Lets see this alloy pulley of yours then maybe that will help ??
Old Apr 17, 2006 | 10:35 PM
richm's Avatar
richm
As said above, it WON'T work unles there is ferrous (ie magnetic) material in the lugs. Ideally the ferrous targets need to be at least the same face area as the polepiece in the middle of the sensor to get a decent signal.
Old Apr 18, 2006 | 06:17 PM
abdr500's Avatar
abdr500
so if i fitted lets say steel screw in the place of the lugs will it work then
Old Apr 18, 2006 | 06:18 PM
abdr500's Avatar
abdr500
or does any one have a photo of one with the grub screws fitted or a pic of a proper one
Vincereese
Aug 15, 2015 06:24 PM
Aug 14, 2015 07:29 AM
pegaz
Aug 12, 2015 07:30 AM
Vincereese
Aug 11, 2015 08:44 AM
Old ford
Jul 31, 2015 06:50 AM
