electrical problems
Old Apr 17, 2006 | 08:58 PM
Little_Hoss's Avatar
Little_Hoss
Default electrical problems
when i indicate left my fuse blows
when i idincate rite it doesnt
when i put the hazards on it doesnt
also when you go to press the left 1 it appers that the dash lights dim
any ideas as its doin me nut in
its a s2 if that helps
Old Apr 17, 2006 | 09:06 PM
davidreader5's Avatar
davidreader5
Hi,
If as you say the hazards work without blowing fuse's the earths must be good, try another switch.
Dave R.
Old Apr 17, 2006 | 09:08 PM
Little_Hoss
tried using my mates stalk but that didnt fix it either
unless thats fooked aswell
Old Apr 17, 2006 | 09:17 PM
davidreader5
Take the bulb out of the bulb holder on the side that is blowing the fuses,
and see if it cure's it, do you have the side indicator fitted try with that
bulb also, it seems strange that all is ok on hazards, without looking at the
diagram of the system. if the above cures it trace back with a diagram of the circuit that it is on,
Dave R
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Kam B
Sep 24, 2015 10:40 AM
focus2351
Sep 9, 2015 09:33 PM
