Another nova thread
To keep me in the spirit of novas after breaking mine up I was asked to build up another for a good mate. Its been a long time coming as things have gone up and down over the last year but things are now coming together very well.
The car had a full Harry Hockley plating kit installed to hold the front end together, the rest of the bay was stitch welded then all painted in the original flame red.
The engine parts were brought nearly a year ago, as per most specs it went from being mild to not so mild, I still feel we could of gone slightly further with the engine spec but its my mates money not mine
I have a lot of things to do now but hopefully I expect to have it ready for Santa Pod on the 4th June for him, and also there is a Rolling road shootout that day so should make a appearance there.
Here are some pics
Bay prepped and welded
Painted
The engine arrived back to me a few months back, Looks great and hopefully the power should be plenty for this car too
Me and a mate finally got time to get the engine in on Saturday, due to the competetion mounts it was a pain in the arse to fit as once mounted you could not move the engine about to get it sitting correctly but eventually we got there
Finally my mate trying to look busy with the impact gun, not getting far with a 17mm socket though
I will update the thread with further specs and progress as things get done.
Engine spec for anyone interested is :
Early xe Block bored to 86.5mm
Early lightened and balanced crankshaft
Cat Cams Steel rods with ARP 2000's
Accralite pistons with extra pocketing
Gated Sump
SBD Steel gear kit and nylon relief valve
Blydenstein GM Head with porous fix, ports and throats have only been modified
QED 450 Camshafts
QED Solid lifters
QED Double Valve Springs
SBD Vernier Pulleys
Jenvey taper TB's on MBE 967 ecu
Bosch motorsport injectors (not pictured)
Simpson race exhaust and manifold, fully slip jointed with re packable back box
Engine built by Odell Motorsport and will be mapped by Steve Greenald of Track and Race
Here are some pics
Painted
Gated Sump
QED 450 Camshafts
QED Solid lifters
SBD Vernier Pulleys
Update :
I have had the wiring loom in bits and taken out everything not required and now routed it back through the engine bay, fitted a few tanks and wipers etc..
I spent a while messing around with the engine mounts to get the engine to sit nicer only to find that when I fitted the exhaust manifold that it hits the drivers side tie bar
some fettling is clearly required here
Got quite a few smaller jobs done too and hopefully tomorrow the bits from rally design should show up so I can get the coilovers back on and brakes etc..
Will keep updating as things get done
pics:
some fettling is clearly required here Got quite a few smaller jobs done too and hopefully tomorrow the bits from rally design should show up so I can get the coilovers back on and brakes etc..
pics:
Originally Posted by JonnyBravo
Nice to see you had somewhere to put a oil catch tank
fook knows where I'm going to find a home for one in there without buying a bufty bailey one
coke bottle in the drivers side wing you girl
Well nearly a year later the car is going back together, due to allsorts of reasons it took a bit of a backseat last year but I managed to convince my mate to hold out until things were sorted.
So with the new year we got back on it and started sorting things properly and hopefully fitting it up for the last time
Loom is now properly stripped of everything that had been added over the years, the front end of the car is now 90% complete.
Parts still required are:
90mm trumpets
Filter backing plate (without holes everywhere rob !)
Bailey catch tank
Aeroquip
Injectors
Then the interior needs sorting, its looking rather sorry for itself at the moment but it should soon be filled with aeroquip, buckets and a nice dash setup.
I'll just stick the pics up I've recently took, car WILL be on the road by April and mapped by May
Possibly a bit flat
Next step is fuel system which really is the last major thing needed, hopefully will get all that by the weekend
90mm trumpets
Bailey catch tank
Aeroquip
Injectors
Possibly a bit flat
The "ecowrecks" imo are no where near as good as the earlier xe's.
Shame as most modern engines are far better than the older stuff but the xe will remain one of the best NA engines about for a few years yet
TBH, its more of a track car than road car, will certainly upest a few others on the road given the chance
How about trying it out on the PF test track
might have to get a few vauxhalls on the pf test track next year
looking good mate ad's will be well impressed
when shall i drop mine off so you can finish rebuilding it ???
I was expecting a much cheekier reply lol
Yeh I agree I'd like to test it out but tbh I imagine 90% of the others wouldn't
Are they afraid ? JOKE
Whenever matey lol, garage should be clear soon, think I'm going halves on a proper unit so we can build my escort and a mates Ultima yeeeah.
Now wheres that payrise
Are they afraid ? JOKEWhenever matey lol, garage should be clear soon, think I'm going halves on a proper unit so we can build my escort and a mates Ultima yeeeah.
Ok small update.
A few parts showed up today so thought I'd get them fitted and finally find out how little room (if any) we had to fit the filter.
Originally the trumpets were chopped down slightly and drilled for nitrous injectors, these were fine for when using nitrous but shocking when your not so a new set was purchased. The problem was that they are big and clearance between them and the bulkhead was extremely tight so it was hit and miss if the firewall was going to have to be cut off.
After squashing the filter into a shape it wasn't overly happy about I managed to get it on which although its tight to the firewall shouldn't be a problem as the engine is nigh on solid mounted, time will tell though.
Heres the pics of the trumpets etc..
As you can see its mega tight but I'm confident that it will be alright.
Only other part that showed up was a 11" Pacet Fan, it took all of 5 mins to fit but its another step closer to being complete now
Whilst I had my mop to hand I thought I'd just buzz over a part of the roof to see if there was anychance of improving the paint where it had faded so much, besides making a fooking mess everywhere I think it will come up fine, the edges are always a pain on red cars as you cant go anywhere near them with the mop so they will need to be finished by hand.
Please take note of what is reflecting in the roof lol
And thats it till the weekend, still waiting on the aeroquip and a few other parts but its really starting to get close to running finally.
Ok at last "most" not all the fuel bits turned up today.
I hoped for blue and red fittings but at the price I got them for I wont be complaining lol
Weekends job as the owner is up again is to get the underside of the car finished, some interior work done and fit some fuel lines where possible.
Heres some pics to tease you with
Well I've just been informed there not actually Aeroquip but they are Goldline fittings, apperently more expensive so I await the bill
I got them through a guy I know locally, mainly extras he has left over from rally car builds so the other ones he didn't have will have to be brought at rrp
Well I think for once we might be on the homeward straight
Sorted out the expensive aeroquip issue and replaced it all with normal fittings and correct hose.
Whilst in the aeroquipping mood we decided to run all the brake lines inside to keep it simple under the car.
The only other problems we have encountered is the oil cooler having the wrong fittings welded on for me
wrong fittings for the bias lever and master cylinder and a exhaust system that is going to require a fair bit of modication to fit nicely.
Time really is getting on now with only a month till the Performance Vauxhall show, I have hardly anytime to work on it so its going to be a long month !
Heres a few pics I took the other night, should hopefully have a few more bits done by tuesday
Also got to fit this once its been sent back for a tacho change
wrong fittings for the bias lever and master cylinder and a exhaust system that is going to require a fair bit of modication to fit nicely.Time really is getting on now with only a month till the Performance Vauxhall show, I have hardly anytime to work on it so its going to be a long month !
Just got a few more brackets to make to hold things like the FPR and washer bottle.
Also got to make some serious modifications to the Simpson exhaust as the system is far too long for normal bumpers. As its fixed straight to the body I hope to get the exhaust nice and tight under the car to avoid any scrapages
