Keith Cowie
Old Aug 2, 2004 | 05:35 PM
RSrussell's Avatar
RSrussell
Default Keith Cowie
What happened?
Old Aug 2, 2004 | 05:38 PM
rs_si's Avatar
rs_si
Blew his front diff so only had RWD
His top speed run wasn't recorded either
Old Aug 2, 2004 | 08:58 PM
sunny's Avatar
sunny
Old Aug 2, 2004 | 09:16 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Front diff blew on 1st run (literally sub 0.5sec after launch) as it was standard i was told (std is mega strong, but car is SILLY powerful so was gona be a risk) as uprated one hadnt arrived.
Exploding diff damaged sump so took a while to fix.
Ran RWD only to do a top speed run.
Even with driving over 1/4mile before even putting foot down supposedly he pulled approx 9200rpm in 6th which is WELL over 200mph and woulve won the top speed by a mile...
But the dappy bint meant to be controlling the equipment was too busy chatting to record the time
Old Aug 2, 2004 | 09:29 PM
RSrussell's Avatar
RSrussell
pisser
Old Aug 2, 2004 | 09:32 PM
RANJ's Avatar
RANJ
Front diff blew on 1st run (literally sub 0.5sec after launch) as it was standard (std is mega strong, but car is SILLY powerful so was gona be a risk) as uprated one hadnt arrived.
he was using an uprated diff when i was talking to mark about his car
Old Aug 2, 2004 | 09:53 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Nope.
The Giken Diff hadn't arrived so had to use standard Nissan. It lasted about 1/10 of a second. On inspection, it had stripped teeth clean off both the crown wheel and pinion
Old Aug 2, 2004 | 09:55 PM
RANJ's Avatar
RANJ
me gettin confused witht he one he wanted to use
Old Aug 2, 2004 | 10:31 PM
ADUSR33's Avatar
ADUSR33
im sure he'll be back
S1 Barkham
Jun 18, 2005 10:21 AM
Cam
23
May 30, 2005 09:10 AM
chris-m
13
May 18, 2005 08:43 PM
chris-m
65
May 18, 2005 06:16 AM
chris-m
May 1, 2005 12:17 AM
