Hi Specced 2 WD Cossie just in for breaking
Super Moderator
in black shell scrap as its been vandalised
ENGINE IS NEW AND HAS NOT YET BEEN STARTED
200 Cosworth Block bored to +.5mm
New Mahle Pistons to suit with C\R of 7.8:1
Peened Rods with new small end bearings
Crank Ground .25/.25mm with new competition bearings
New oil pump
Totally overhauled head by PJ Motorsport with new guides and stem seals,
crack tested and skimmed
Group A head gasket and new Bolts
NEW ARP Big End bolts
All new gaskets used throughout,
2WD Sump fitted
Red Rocker Cover with new screw oil cap
4x4 Inlet manifold with larger plenum, throttle body, ISCV and TPS
New timing belt and cams will be timed
£2000 SOLD PENDING PAYMENT AND COLLECTION
Gearbox £350
Rear Diff £250
Brand new T34 by Turbo Techniques not yet run £600 (cost £800)
4WD Exhaust manifold £100
Greens chip and 3 Bar £300 again all new
330mm Alloy Comp front brakes £550 (new) SOLD TO AlVYN
Alloy twin strut brace £100 SOL
Baily Breather with fitting kit £100 (new)
Baily Header Tank £120 (new) SOLD
Baily Swirl Pot £60 (new) SOLD
Twin intercoolers fabriacted togeather £100
Konis full set £200
Leather trims from £400
Samco boost and water hoses SOLD
Stainless Cam belt cover £100 (new) SOLD STUCOS see you Sunday
Alloy 2 WD quick shifter £125 (new) SOLD TO THE FAT BARSTARD FROM SCARBROUGH
Black 4WD Bonnet £200
plus loads of the usual parts anyone interested please call me only do not send E mails or PMs as I will be away from my PC untill Friday
New oil pump
2WD Sump fitted
Gearbox £350
Rear Diff £250
Konis full set £200
The "FAT BOY " is on his holls , so your better calling him ,,He will have his mobile with him and will answer as he is a propper sad b......d and takes it everywhere with him ( even the bog )
Paul
ps, keep your bloody hands of the quick shift tho , its mine
Paul
Paul
Paul
Super Moderator
Originally Posted by SPADGE
Pete is the front brace a proper one that bolts to the inner wings or one of those with the hoops around the top of the leg?
Cheers Spadge...
Cheers Spadge...
Super Moderator
Paul
Paul
chowfornow
14
Jan 5, 2019 09:01 PM
muz
Sep 30, 2015 08:29 AM
