Clip that holds heat shield to air box lid
Old Apr 15, 2006 | 04:41 PM
MATCOS's Avatar
MATCOS
Default Clip that holds heat shield to air box lid
Can these be bought seperately?
I may have lost mine and will need a new one
Old Apr 15, 2006 | 04:51 PM
rapidcossie's Avatar
rapidcossie
Default Re: Clip that holds heat shield to air box lid
just zip tie it!
my fav tool!
Old Apr 15, 2006 | 05:05 PM
MATCOS's Avatar
MATCOS
just zip tie it!
my fav tool! [/quote]
Im not bloody zip tying it mate
Old Apr 15, 2006 | 05:12 PM
cahzz's Avatar
cahzz
mat ive got a very cool mod to this that looks better than o.e
basically get a brand new nut on bolt, slip the bolt in the airboc side and then tighten the nut on the insde of the airbox, it does the job perfectly and you cant see it, it looks exactly the same as o.e the best thing is youve got adjustment, the more you tighten the closer it pulls the heatshield up, you can get it to line up perfectly witht he cam cover like ive done
Old Apr 15, 2006 | 05:13 PM
cahzz's Avatar
cahzz
works like a treat for me
Old Apr 15, 2006 | 06:05 PM
MATCOS's Avatar
MATCOS
Nice one mate - I will give this a go later
Old Apr 15, 2006 | 06:08 PM
cahzz's Avatar
cahzz
so just to confirm with you, slip the head of the bolt into the airbox sleeve/hole, then the threaded part goes through the hole in the heatshield, then nut on the inside of the heatshield, really works well and looks o.e except youve got adjustment!!
imnoteasy
Aug 30, 2015 09:34 PM
rog
Aug 30, 2015 05:32 PM
Franko99
Aug 29, 2015 01:38 PM
David Potasnick
Ford Fiesta
Aug 22, 2015 10:54 PM
track.focus'd
Aug 12, 2015 05:53 PM
