S2 wont run now,can u lot help???
Old Apr 14, 2006 | 10:19 PM
escortlad's Avatar
escortlad
Default S2 wont run now,can u lot help???
Hi,someone must be able to help,my s2 has been runnin fine the whole time ive had it but tonight i got this problem,i only drove abot 6 or 7 miles to a mates,and as i was almost there it would cut out on idle,just didnt want to tick over,so i thought it must be a air leak and found a pipe off (not sure what its called)but it connects down below the mfi inlet unit,hard pipe which goes into sumink round?well i reconnected it and thought it would be fine,started it up and ticked over again fine,i reved it from the cable while i looked at the engine and it cut out when revs died down and wont start now and feels jumpy when i turn it over?
can any1 help me on this please?
cheers
Old Apr 14, 2006 | 11:42 PM
NUTS RuS's Avatar
NUTS RuS
Was it just problems on idle or could it be fuel pump related do you think ?
Whats 'jumpy' mean ??
Old Apr 14, 2006 | 11:44 PM
escortlad's Avatar
escortlad
as long as i kept the revs up it was fine,lumpy/jumpy kinda thing,not really bad but noticable?any ideas?
Old Apr 14, 2006 | 11:55 PM
NUTS RuS's Avatar
NUTS RuS
Just reads like another air leak to me, at first I was thinking fuel but if it runs ok it can't be. Have another look round
Old Apr 15, 2006 | 12:08 AM
SafeChav's Avatar
SafeChav
Sounds like an air leak to me aswell. If you have boost/vacuum gauge looking at what it does will tell you a lot.
Old Apr 15, 2006 | 02:42 AM
escortlad's Avatar
escortlad
since i put the pipe back on it started up fine then was ticking over for a minute then i revd it and it just died when the revs went down and wont start again atal,so im not sure what my boost gauge will read but it was under boosting befor i fixed the pipe?
Old Apr 15, 2006 | 07:56 AM
SafeChav's Avatar
SafeChav
Look for eratic vacuum readings when its idling etc
Old Apr 15, 2006 | 09:09 AM
escortlad's Avatar
escortlad
if i get it started i will,cheers for ur help so far neway people
YODI
Aug 30, 2015 01:12 PM
Red_bull
Aug 25, 2015 06:27 PM
ekjim
Aug 17, 2015 08:57 PM
allye
Alloy wheels and ICE for sale
Aug 11, 2015 09:49 PM
Adam-M
22
Aug 10, 2015 10:46 AM
