abs
update on my abs probs,ive checked fuses, relays,all ok,tried another reservoir cap,but abs light is still on,ive cleaned the sensors but not checked them yet with multi meter, but i was wondering would the removal of my airbag/light cause the abs light to come on? are they connected in any way with them both being safety features?
Originally Posted by Tandy
Radman--- any joy with the abs light as i have same prob also where are these sensors?
update time again, ive swapped all the sensors and made no difference,
so worth checking out yours if you have similar problems
ummm...this is a big turbo right? My small turbo light has been on for about a year, all tests done...nothing. This is interesting, but the small turbo doesn't have a HT lead like your description does it...(i wish it did) then my problem could be sorted too....
