phase sensor gap?
Old Apr 11, 2006 | 10:22 PM
puddy's Avatar
puddy
Default phase sensor gap?
Trying to start the tina engine for the 1st time since it was dyno'd a few years ago,but it sounds like it wants to run backwards,sort of like leads on wrong?
Went through the usual stuff and concluded phase sensor,fitted a new one but its still the same ,whats the correct gap?
puddy
Old Apr 11, 2006 | 10:30 PM
boXXer's Avatar
boXXer
GASH!
workshop manual says "0.2-0.3mm" mate. HTH.
Old Apr 11, 2006 | 10:33 PM
bud-weis's Avatar
bud-weis
Football Cwazy
presumably leads are on correctly and the rotor arm is in the correct position?
this pic may or may not help
Old Apr 11, 2006 | 10:36 PM
JjCoDeX75's Avatar
JjCoDeX75
Hi m8,
If you plug the phase sensor in the wrong way round, the engine wont start. I know this from bitter experience. I wont tell you how long it took me to work out that this was the problem!!!!!
The correct gap is :- 0.2 - 0.3mm (based on the Ford Tech. manual.
Cheers M8
JJ
Old Apr 12, 2006 | 06:47 AM
puddy's Avatar
puddy
Cheers,Deffo got the firing order right,will check the gap and lead tonight.
puddy
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
