Help with a smoking cossie PLEASE.
Old Apr 11, 2006 | 03:15 PM
Finny's Avatar
Finny
Default Help with a smoking cossie PLEASE.
On the wkend we changed the t3 for a t34. t3 was running with greens, 3bar, chip. NO probs with it. Put the t34 on which has never been on a car, (brand new). Aslo fitted induction kit, with new hoses. Binned the airbox. Got a spec r breather that fits to both sides of the block. Not fitted yet however, the fire trap side of the breather is left open to breathe into atmosphere. Now on start up i get some blue smoke out the exhaust, when driving though and car is warm when you back off LOADS of blue smoke AND WHITE SMOKE when you get back on the throttle LOADS MORE of white smoke. AND IT,S DOING MY F*cking head in. So please could someone give me an idea as to how i sort this out. Sorry it,s took sooooooo long to explain.
Old Apr 11, 2006 | 03:16 PM
Graceland's Avatar
Graceland
Team HOTHOT!
turbocharger is wankered.
remove, return, replace
Old Apr 11, 2006 | 03:17 PM
GARETH T's Avatar
GARETH T
i hope your not driving it with the t34 on? you know it would be lean?
Old Apr 11, 2006 | 03:28 PM
Finny's Avatar
Finny
Graceland, the turbo is brand new mate how can it be f*cked if you really think it is wot could be wrong with it?
Old Apr 11, 2006 | 03:58 PM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
just because its new doesnt mean its gonna be ok, a few of my units have had sealing issues using brand new genuine parts, send it back it will be fixed
Old Apr 11, 2006 | 04:41 PM
Rhys's Avatar
Rhys
NIghtmare to hear this Finny, fookin feel sorry for u dude! Does sound like turbo seals though.
Gareth that really isnt issue atm, as Finny is just driving car around sensibly till its been set-up.
Old Apr 11, 2006 | 05:51 PM
Finny's Avatar
Finny
thanks for the replys it seems that people think that the seals in the turbo are shot. where,s the best place to get it all sorted out?
Old Apr 11, 2006 | 05:59 PM
Graceland's Avatar
Graceland
Team HOTHOT!
the man at RADesigns who posted above
Old Apr 11, 2006 | 06:00 PM
saphycozzie-adz's Avatar
saphycozzie-adz
turbo technics are very reputable
Old Apr 11, 2006 | 06:27 PM
Daveyboy's Avatar
Daveyboy
Are you hooning it around with the chip for the T3 still in it? or have you replaced that as well?
Old Apr 11, 2006 | 07:15 PM
Rhys's Avatar
Rhys
Read above
Old Apr 11, 2006 | 07:53 PM
Billabong's Avatar
Billabong
Can you clarify that? Do you mean that whilst you haven't yet fitted the breather kit, you've let the firetrap pipe vent to atmosphere?
To breathe from both sides of the block, ideally you want to breathe from the firetrap location, the blanked off bit under the exhaust manifold, and have an oil return to the sump itself (below oil level), and then vent to atmosphere or catch tank.
Old Apr 11, 2006 | 08:13 PM
big_wig_074's Avatar
big_wig_074
Sort out the breathers matey,this is a common fault on 200sx's,the breathers are crap on them,and the cars smoke all day long,which looks like turbo problems,but isnt! and your problems suggest this to me,so get it plumbed in right and u should be ok
Old Apr 11, 2006 | 08:26 PM
Finny's Avatar
Finny
thanks for all the replys guys on this. i still have the t3 chip in it as i want to take it and get it chipped for the t34 and live map it at the same time. The breather is not fitted either but the engine is breathing from the open fire trap on the right hand side of the block. But with the spec r breather fitted it will breathe from both sides and cam cover. Please could you guys tell me that once this is all in place do you think that it,ll stop smokin and will the live map help???
Old Apr 11, 2006 | 08:34 PM
big_wig_074
the breathers SHOULD help the smoking,the live map will stop the shiny metal bits melting and pouring out the breathers as well as the oil!
Old Apr 11, 2006 | 08:35 PM
big_wig_074
gcfcos
59
Oct 6, 2015 05:04 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
A.t.p
Sep 29, 2015 05:04 PM
