Fiesta Turbo uprated actuator fitment
Old Apr 10, 2006 | 07:46 PM
tallboy_ed's Avatar
tallboy_ed
Default Fiesta Turbo uprated actuator fitment
I have fitted beige injectors, stage 2 chip and need to fit my new uprated actuator. The thing is i need to put the actuator on so i can take it o be set up properly on the rolling road. Can anyone please tell me how long the rod needs to be??????????????????HELP.
Old Apr 14, 2006 | 04:51 PM
SafeChav's Avatar
SafeChav
The actuator should be adjusted depending on how must boost you want to run at lowest.
Fit the actuator and adjust it so the there is a little pre-load and so that the wastegate isn't loose, and then take it for a test,(be careful) it should run next to no boost, then its a bit of trial and error adjustment, making the rod shorter for more boost and vice versa.
Matt Baxter
Sep 16, 2015 08:30 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
