High clutch pedal
Old Apr 10, 2006 | 01:43 AM
Coxy_UK's Avatar
Coxy_UK
Default High clutch pedal
Forgive my lack of mechanical knowledge, but the clutch pedal on my 2wd saff is up too high though the clutch itself doesnt slip and the biting point seems fine. Can this be adjusted and if so how? cheers
Old Apr 10, 2006 | 08:31 PM
JamesH's Avatar
JamesH
Pull the clutch pedal up and it will re-adjust itself
Old Apr 12, 2006 | 10:51 AM
Coxy_UK's Avatar
Coxy_UK
I can't seem to pull it up, it's already as high as it will go.
Old Apr 12, 2006 | 05:35 PM
w_wall_2001's Avatar
w_wall_2001
i have the same problem. cant seem to pull it up any futher either
Old Apr 14, 2006 | 11:04 AM
JamesH's Avatar
JamesH
Strange, shouldn't take too much effort if pulling it up from under neath the pedal with the foot
Old Apr 15, 2006 | 06:59 PM
Coxy_UK's Avatar
Coxy_UK
It really wont come up any more though! There is no upward movement.
Old Apr 17, 2006 | 08:27 PM
Coxy_UK's Avatar
Coxy_UK
can anyone help??
Old Apr 17, 2006 | 10:11 PM
nicksaph's Avatar
nicksaph
the clutch pedal on all my sierras has been higher than the brake pedal mate, if its not slipping and working ok i shouldn't bother about it
Old Apr 22, 2006 | 08:48 PM
jim393's Avatar
jim393
If the clutch pedal feels like there isn,t any slack right at the top as you just start to push it. This means either the little plastic pawl on the clutch ratchet is worn or the metal tab it sits against which is also the stop is worn. My one was worn and it caused the ratchet to keep adjusting the clutch cable up and when driving car hard the clutch started slipping. I changed pedal box and fitted new ratchet clutch feels much nicer.
Old Apr 23, 2006 | 07:05 AM
Coxy_UK's Avatar
Coxy_UK
thanks for that, will look into it.
i also get a strange noise, heard mainly in 5th gear. i really dont know how to describe it. kind of like a minor rubbing/grinding, but its not constant
