4x4 clutch adjustment
Old Apr 9, 2006 | 03:31 PM
pee vee's Avatar
pee vee
Default 4x4 clutch adjustment
can it be done!?
new engine, new clutch and its biting right at the very very top
so i think it will just slip if i drive anywhere....
can the self adjustment bit be re-set???
Old Apr 9, 2006 | 03:34 PM
rapidcossie's Avatar
rapidcossie
cable maybe stretched?
Old Apr 9, 2006 | 03:38 PM
pee vee's Avatar
pee vee
not sure mate.
its as if the cable is too tight,, as the clutch releases as soon as you put your foot on the pedal
Old Apr 9, 2006 | 08:26 PM
CosKev3's Avatar
CosKev3
Could be over adjusted,pretty sure you release it by pulling the pedal upwards,stick your foot under the pedal and pull it back towards you
As said above,stick a new cable on,allways get the best from your new clutch then
A.t.p
Sep 29, 2015 05:04 PM
mpilk
Sep 27, 2015 09:21 AM
