Brakes still a little spongy after bleeding...
i bled them again yesterday (using ezibleed) and theyre better, but not as amazing as i rememebr them being after i 1st sorted em out...
i bled thru approx 3 quarters of a litre of dot4. and the fluid was last changed a few months ago (for brand new dot4)
not all of the brake lines are braided either...
it dont bother me too much coz the brakes are still very good, but if theres something obvious worth checking then i wanna check it... just incase
ideas?
ideas?
chrissy, when i changed the discs n pads i killed the master cyl when bleeding
i now have on there one i got from the scrappy...
doesnt appear to be leaking... ie no sign of brake fluid on the outide... also when i was using the ezibleed i couldnt see any fluid seeping from anywhere... it apreared pressure tight
had it on my bros golf master cylinder change all is good
not summit u wanna scrimp on brakes imo
