AEM EMS in a Cosworth?
Old Aug 1, 2004 | 12:12 AM
gibbon75's Avatar
gibbon75
Default AEM EMS in a Cosworth?
Is it possible to use AEM EMS in our cars?I don't think AEM makes a direct harness plug for the Cosworth,but maybe we could make it work.Or maybe there's somebody who's using it already?I think it's cheap(around 1300 USD) and it has many good functions+user friendly mapping.
Old Aug 1, 2004 | 12:16 AM
DazC's Avatar
DazC
What is wrong with the origonal Weber ECU?
My Dad's Sapph is running 750cc injectors with lambda 1 at idle on the standard Sapphire level 8 lambda control ECU....
You can fit any enigne management system to any car if you know how....Most people run Autronics and Pectel. There is also a few starting to run SECS
Old Aug 1, 2004 | 12:37 AM
gibbon75's Avatar
gibbon75
original ECU has no launch control,traction control for example
you can't set the right amount of boost for a good launch with the original ECU
and so on
Old Aug 1, 2004 | 12:45 AM
DazC's Avatar
DazC
Fair enough....
I you want them features then a swap is neeed...
Old Aug 1, 2004 | 09:00 AM
GT2's Avatar
GT2
It should be possible to buy the AEM system with a flying lead set and then you can make it fit your car yourself. If not you can buy it from a Gems dealer in the UK because the ECU itself is made by Gems.
If You want an EMS systems but still retain standard harness and so on go for an Gems Lvl8 or P8 implant board, gives you everything you want but still looks standard.
Old Aug 1, 2004 | 09:49 AM
gibbon75's Avatar
gibbon75
Thanks mates
Billy_RS
Sep 13, 2015 04:17 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
