hard to change gear in my saff
if i drive normally then my box is perfect but when im giving it large it becomes hard to get a smooth gearchange especially from 2nd to 3rd.....nearly every time i try and change when giving it beans i miss the gear coz it just wont go in..........whats the problem???...ive been told selector forks from too much abuse........is this correct or what else could it be.
And yes the clutch is fine , its a 6 paddle jobbie which is spot on.
no i havent mate......i'll give this a go i think then if it doesnt work then it hasnt cost me much. Whats the best oil to use on the saff?? and how much does the 2wd saff box take??
i think when your giving it some as youve said, we try and change up so aggresive, you just cant find third
as youve said in your post, its perfct when your driving normal, so if there was a problem surely it would be there all the while
just a thought anyway mate..
i can beat the syncro on my gear box quite easily..
it is also harder to change the more power you have...
i noticeably had to slow things down after having the new engine fitted or esle it just bages like fook every time you change gear.
slow (or just not warp speed) and smooth is best
Adam Graham
Sep 6, 2015 06:04 AM
