cossie webber 2wd fpr
Old Apr 6, 2006 | 11:24 PM
muppetsport's Avatar
muppetsport
Default cossie webber 2wd fpr
bought one of the above for my (ahem) corsa turbo to replace an fse, which gave me no end of problems. the webber one sorted the miss-fire out instantly. but adjusting it seems to be quite difficult. with the 4mil allen key in the top, ive turned it not nearly 1 whole turn. on the wideband lambda gauge in the car it shows that it is going leaner, the way i want it to as previously it was reading in the 10's on the gauge. now about 11. every now and again it flicks into the 9's though say in 6th gear on full throttle.
just wondering if this could be the regulator or maybe the dizzy cap or rotar arm isnt giving enough spark?????? car is running around 1.8 bar of boost and it holds it at 1.6
many thanks in advance
Old Apr 7, 2006 | 12:04 PM
foreigneRS's Avatar
foreigneRS
Testing the future
you can't 'map' an engine just by fiddling with the fuel pressure
Old Apr 7, 2006 | 12:08 PM
muppetsport
im not trying to map it. im just trying to get the fuel pressure right for the injectors its running. the ecu already has a map in it for 1.8 bar of boost. basically turning the fuel pressure down to bring the fuelling back into line.
i was just wondering more if the readings on the lambda gauge showing it rich could be to do with a weaker spark perhaps and not the fuelling?
mark r
Sep 29, 2015 07:27 PM
A.t.p
Sep 29, 2015 05:04 PM
arfurski
Sep 26, 2015 10:39 AM
IainRS1700T
Sep 25, 2015 06:44 AM
dojj
28
Sep 11, 2015 10:00 PM
